Old 06-06-2002, 08:25 PM   #1
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Angry Poor cooling on AC, good on gas
I started to cool the fridge in my new 2003 International on 110v. Freezer compartment got pretty cold, but fins in rest of box barely got cold. The box only went down to about 60.
I then started it on propane and it fairly quickly went down to under 40. I switched back to 110v and checked again in 2 hours. It was back up to near 50. Back to gas and the temp is going back down again.
We're leaving in the AM for the weekend and we can just keep it on gas.
The thermostat apparently works in the propane mode. Seems to me I ought to check thge resistance of the AC element for starts and make sure that the connections are all tight.
Anyone have any other ideas of what may be happening?
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 06-13-2002, 10:46 PM   #2
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Warranty repairs...
You are right, it should be much cooler on 110AC.
I believe I would have to take it back to your Airstream Dealer. From your previous posts I see that you have a 2003 model. I would get this fixed under warranty.
Just my .02 cents.
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
servicing gas part of refrigerator nickcrowhurst Refrigerators 3 02-21-2006 07:46 AM
Gas Furnace ketchumwt Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-04-2003 12:46 PM
Yukon AC cuts out towing.... dscluchfc On The Road... 10 07-27-2002 11:01 AM
