Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 10-06-2009, 04:29 PM   #1
Profile:  Hanover , Connecticut
Unhappy Please Help with Suburban NT-30M Furnace before I rip off all my skin.
Hey folks. I'm at my wits end and sure could use some advice. I have an older Suburban Dynatrail Furnace, NT-30M. It starts perfectly, fires and heats like brand new. When the temperature is reached it promptly cuts off the burner and then the blower continues to run, and continues to run, and continues to run, and continues to run, and......(you get the picture). Today I just spent $125 on a new Dinosaur board and replaced the old original board. I must say it starts and runs better, but the blower fan still doesn't ever shut off after the temperature is reached. When I say never shuts off, I mean like an hour later it's still running. I don't understand what the problem is. I assumed it was the board and that's why I replaced it. This unit does not have a separate fan-control relay. Could it somehow be the wall thermostat? I don't understand why that would be. I know some of you will say to just replace it, but it works great otherwise. I recently cleaned the burner out and it seems solid as can be. Help, help, help.
berea777 is offline   Reply With Quote
Old 10-06-2009, 06:22 PM   #2
Minno's Avatar
Profile:  1972 31' Sovereign
Lexington , Minnesota
Hi and welcome to the forums!
Will the blower shut off if you turn the thermostat down? I mean after you say set it for 70, and it heats the trailer up to 70, if you bump the thermostat down to 65, will the blower shut off?
Have you tried replacing the thermostat?
Minno is online now   Reply With Quote
Old 10-06-2009, 07:18 PM   #3
Profile:  1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I am taking an educated guess here without a manual in front of me but as i remember it the sequence when you turn up the thermostat should be, blower comes on, after a time burner lites, the early run is to clear gases from the furnace., when temp is reached the burner shuts down.. If it does this your thermostat should be ok. There is a thermodisk thermostat somewhere near the heat exchanger that comes on when the furnace reaches a certain temp. Once this closes the fan will continue to run after the burner shuts down.. After cool down it is supposed to open shutting off the fan.
This is most likely the culprit. This looks like a piece about the size of a quarter with a couple mounting ears on it and 2 wires.
They are usually marked with a temperature range and are inexpensive.
If I am off base, my apologies. My book for that furnace is not here right now.
Rick Davis 1602
PP VAC 2002-03
61 tradewind, 70 Globetrotter
69 Ambassador 64 Overlander
K8DOC
Phlogiston deficiency in Suburban NT 30M Excella CM Furnaces, Heaters, Fireplaces & Air Conditioning 12 05-23-2008 09:44 AM
Suburban furnace pjude General Motorhome Topics 4 10-16-2007 09:00 AM
Suburban NT 30M Furnace quick fix Chuckles Furnaces, Heaters, Fireplaces & Air Conditioning 0 02-04-2006 03:27 AM
Dented skin repair from awning rip-off givememoreli Ribs, Skins & Rivets 3 07-18-2005 07:28 PM
Suburban Furnace tmeagle1 Furnaces, Heaters, Fireplaces & Air Conditioning 25 02-20-2004 08:18 AM
