Old 11-22-2013, 06:44 PM   #15
groovzilla's Avatar
1966 20' Globetrotter
Seattle , Washington
it turns out the drip pan was so dirty that there were a series of rivets hiding along the middle of the pan and also 4 rivets around the hole that the wires and copper tubing go thru.
everything is removed.
**i was able to remove the a/c unit from the roof myself using a ladder on a severe angle to gently slide it down the ladder - easier than setting up scaffolding or other procedures i've seen posted
**i used arrows to show where the not so easy to find rivets are that get covered with dirt. large hole is for wiring/copper tubing - small hole is the fan shaft
ID:	200538   Click image for larger version
groovzilla is offline   Reply With Quote
Old 11-22-2013, 10:33 PM   #16
1968 26' Overlander
West Richland , Washington
68' Overlander
Groovzilla,
I too have a 68 Overlander and have gone thru it quite a bit, including the AC removal you describe. When I install my nes a/c it will be thru a new 14" sq opening.
If you are doing a remodel of the interior, you might find that the interior skins have to come off for electrical rewire, relocating outlets, re-insulation, etc. My interior a/c blower had to come out to remove rivets from the interior ceiling skin. I was a little reckless with my old unit and cut and hacked so it was not reuseable. Please let us know how the preservation comes along.
JIMandPJ is offline   Reply With Quote
Old 11-23-2013, 05:53 AM   #17
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I don't know enough about ACs to be 100%, but have never seen an Armstrong that does not use the 14x14 roof opening.
Around these parts I could not find anyone to work on an Armstrong. From what I understand a major problem is replacing the freon is prohibitably expensive.
2nd A/C for a 34' - 2002 Classic HighFlying 2001 - 2005 Classic 10 11-17-2011 07:04 PM
A/C leak only with sideways rain Bowmans Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 10-07-2011 10:47 AM
1968 A/C not spinning fans on startup? hayduke Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-05-2011 09:21 PM
Second AC pendletonkm 2011 - 2015 International 3 07-19-2011 12:32 PM
No Power To A/C (power at breaker) vhariable Electrical - Systems, Generators, Batteries & Solar 3 06-28-2011 05:54 PM
