Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 12-16-2007, 11:40 AM   #1
slimitch
Profile:  St Louis , Missouri
Pilot light 72 safari
Cannot get my pilot light lit in my 72 Safari with a Suburban heater. Gas is on and there is a shut off value on the copper tubing just before it enters the heater. That is also on. Don't thnk I'm getting any gas to it. Is There somehitng else I need to do?
slimitch is offline   Reply With Quote
Old 12-16-2007, 11:44 AM   #2
cameront120
cameront120's Avatar
Profile:  1972 25' Tradewind
Could it be clogged? I've heard that it is a common place for getting clogged. Has the outside shutoff towards the front of the trailer been turned on?
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
cameront120 is online now   Reply With Quote
Old 12-16-2007, 12:03 PM   #3
slimitch
Did not see an outside cutoff valve. Where is it located?
Old 12-16-2007, 12:19 PM   #4
Blu_Hwy_Lady
Blu_Hwy_Lady's Avatar
Profile:  1972 23' Safari
Placitas , New Mexico
I have a '72 Safari with the original Suburban and it is really, really hard to light. First, turn on the all burners on the stove. Maybe it's just my wishful thinking but that seems to "pull" the gas through the line. I think the secret is to use one of those long lighter dealies and just hold the flame over the pilot area for about a minute before you even start to try to light it. Maybe that warms up the thermacouple (<-sp?) I don't know. I get in this contortionist pose of using my foot to hold down the "press" button while I try to light the pilot. Eventually it gets going, but it is very frustrating when your freezing.
Good Luck
Airylle (Susan's 1972 Safari) featured for 5 nanoseconds in the movie Wild Hogs
pulled by Jak the Blue Mule (Bill's 2001 Dodge Cummins)
and
Jupiter (the Golden Retriever puppy)
Athena (the road kitty)
Blu_Hwy_Lady is offline   Reply With Quote
Old 12-16-2007, 12:21 PM   #5
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
The gas valve for the furnace is located either on the side of the furnace, or immediately underneath the trailer mounted to the underbelly.
You would be wise to remove the furnace and have it "bench" torn apart, cleaned and repaired as necessary, and then bench tested.
There are some gaskets that will need to be replaced to assure that no carbon monoxide gets in the trailer.
Unless your familiar with LPG furnaces, you should seek professional assistance to help you.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Pilot Light Silver Threads LP Gas, Piping, Tanks & Regulators 19 02-24-2007 10:08 AM
Pilot light problem Scott Hopkin Airstream Trailer Forums 3 05-17-2005 04:16 AM
Pilot light in Frig niftypkg Refrigerators 9 04-10-2005 01:04 PM
Can't light furnace pilot light? (again?) Matthew&Gigi Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-05-2005 12:52 PM
Pilot light adjustment thenewkid64 Water Heaters, Filters & Pumps 9 02-25-2003 05:04 AM
test
