Old 05-16-2014, 11:33 AM   #1
1977 31' Excella 500
portland , Oregon
Permanent A/C removal.
Hello all,
I am debating on the complete and permanent removal of my 77 excella's air conditioning unit. I am planning on full timing, but have never been one to use a/c, even in a home.
My question is this: with the replacement and upgrade of all fans do you think the airstream will still overheat?
CorySessums is offline   Reply With Quote
Old 05-16-2014, 11:35 AM   #2
portland , Oregon
I should add that the current unit is not functioning.
Old 05-16-2014, 11:45 AM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by CorySessums View Post
Hello all,
Hi, if you are never going to travel anywhere, this would be fine. But if you go to Arizona in the summer, you will cook. Some people, where they live, never need air conditioning and others never need a furnace. My trailer has been in over 100 degree temperatures and down to zero. I need it all.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-16-2014, 12:02 PM   #4
Gainesville , Florida
If mine quits I will have it either removed and replaced with a smaller unit that will run on one honda 2000 genny, or seal the hole and use a portable AC unit. I already have one and it works fine. You only have to carry it in hot weather. I also do not have a furnace. The portable AC unit needs a 3 inch hole to vent or the use of a window venting kit that came with the unit. Mine does not need a water drain. Jim
Old 05-16-2014, 12:12 PM   #5
Salem , Oregon
Images: 18
Hi, I have and use, a portable air conditioner in my house; Mine can be connected to a drain hose or I just dump the water collecting container when it gets full. Mine will beep and flash a red light when full. How does yours work without a drain?
2005 Safari 25-B
Old 05-16-2014, 02:48 PM   #6
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Drainless units can work because the condensate water is sprayed onto the condenser coil; the re-evaporated water is then blown outside along with the condenser discharge air.
Old 05-16-2014, 02:50 PM   #7
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Here in south Mississippi when the outside temps reach the low 80's it will be over 100 in my trailer. I could not imagine not having a well working AC unit.
MICHAEL
Old 05-16-2014, 03:13 PM   #8
Robersunrus is correct. No water to dump. Jim
Old 05-16-2014, 03:25 PM   #9
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
does the portable unit produce a lot of heat too? I was interested in these, but chose to use a small window a/c which has a temporary mount..
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 05-17-2014, 12:37 AM   #10
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
When the sun beats down on that highly heat conductive aluminum....
The inside of these Airstreams is much akin to a solar oven. Yea, open windows and vents will help, but not enough for me when it is 105 outside and 125 inside..... Sometimes I like to take a nap, sauna naps don't make it for me.
Those portable a/c units, about how long will they last?
I ask because a lot of these kinds of things I see now days don't seem to work for that many years.
The a/c in my trailer is 42, and still running.
Old 08-27-2015, 10:34 PM   #11
1977 25' Tradewind
great cacapon , West Virginia
I would like to say hello, new to forum. Getting back on topic, removing the ac. If it is done, can the hole be covered with a vent like the other 2 holes in the roof? Aftermarket vent/fan? I am doing a complete overhaul on my 77 25" land yacht. Might consider fixing the original armstrong. Can the original run on a 120v 15A connection? Or do i need the 30A connection? I currently have a 30A to 15A adapter for power.
Been doing allot of reading here, very informative. Thx.
bravada94 is offline   Reply With Quote
18' Caravel with permanent bed Zeppelinium Cabinets, Counter Tops & Furnishings 20 11-07-2013 08:44 PM
Creating a permanent Airstream Site gadgetat Full-Timing 12 05-25-2005 07:13 PM
permanent decal & paint stripping 0557 Our Community 1 02-19-2004 05:44 AM
Permanent trailer license? Rog0525 Title, VIN & Registration 21 10-07-2003 10:17 AM
Permanent home? DGR160 Our Community 12 04-23-2003 10:49 AM
