Below is a copy of Post #86 from my
'78 31' Sovereign
thread in my signature line.
Condensate line & 110 wiring for the rear AC
Originally Posted by
Splitrock
... How'd ya deal with the condensation water?
The roof reinforcement, condensation line, and 110 wiring required some creativity. I used a combination of true 2" X 4" (rough cut) Western Cedar lumber and longitudinal 2" X 2" aluminum angle to stiffen up the ceiling for both of the AC's. I purchased the "two single cups" type of water catcher manufactured by Dometic - what a ripoff. The Dometic "Kit" consisted of two formed plastic cups designed to be installed on the interior frame of the Dometic with some 1/2" plastic tubing connecting the two cups - for a bargain price of $65!!! Let's see - $6.50 worth of plastic selling for $65 - that's what - 1,000% profit???
Add that to the unique Dometic "reversed phone line polarity" thermostat complication - and I am less than happy with the Dometic corporation.
I bucked up for two full drip installation pans available via Airstream - a bit pricey but a MUCH better condensate solution than the Dometic "drip kit".
Anyone contemplating a Dometic Penguin installation from scratch should have some looonngg conversations from someone who has already done a greenfield installation.
On the matter of the drip line - I crossed over from the Driver Side to the Curb Side with the drip line, came underneath of the rib just to the rear of the bath/bedroom bulkhead (there is an "indent" in this rib for the
12 volt wiring bundle to pass between the rib and the interior panels - used this "indent" for the 110 volt wire and thermostat wire to the AC also).
There was a double center ceiling panel in the '78 from a previous modification/repair. Fortunately (for me) there exists a large cut out in the area of the black tank vent in the area between the bathroom bulk head void, this cut out allowed for the passage of the 110 wire, the thermostat wire, and the condensate drip line into the wall void in the area of the medicine cabinet/black tank vent.
