Old 08-09-2014, 01:07 PM   #1
Dallas , Texas
Penguin Installation - Do I need to add supports?
Hi all,
I'm replacing the original AC on my '78 Sovereign with a Dometic Penguin II Low Profile unit. There is an aluminum rib on each side of the hole, but the rear rib is about 10 inches behind the hole. Because of this, there's about 10 inches of unsupported aluminum shell/interior aluminum. Is this something that needs to be addressed? I've seen others add a wood support, but it seems that if the original AC was supported fine, this one should be too.
Additionally, can I use the stock drain pan, even though it's not curved? I'm running the Airstream Drain Kit, BTW.
66replica is offline   Reply With Quote
Old 08-09-2014, 01:34 PM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
Below is a copy of Post #86 from my '78 31' Sovereign
thread in my signature line.
Condensate line & 110 wiring for the rear AC
Originally Posted by Splitrock
... How'd ya deal with the condensation water?
The roof reinforcement, condensation line, and 110 wiring required some creativity. I used a combination of true 2" X 4" (rough cut) Western Cedar lumber and longitudinal 2" X 2" aluminum angle to stiffen up the ceiling for both of the AC's. I purchased the "two single cups" type of water catcher manufactured by Dometic - what a ripoff. The Dometic "Kit" consisted of two formed plastic cups designed to be installed on the interior frame of the Dometic with some 1/2" plastic tubing connecting the two cups - for a bargain price of $65!!! Let's see - $6.50 worth of plastic selling for $65 - that's what - 1,000% profit???
Add that to the unique Dometic "reversed phone line polarity" thermostat complication - and I am less than happy with the Dometic corporation.
I bucked up for two full drip installation pans available via Airstream - a bit pricey but a MUCH better condensate solution than the Dometic "drip kit".
Anyone contemplating a Dometic Penguin installation from scratch should have some looonngg conversations from someone who has already done a greenfield installation.
On the matter of the drip line - I crossed over from the Driver Side to the Curb Side with the drip line, came underneath of the rib just to the rear of the bath/bedroom bulkhead (there is an "indent" in this rib for the 12 volt wiring bundle to pass between the rib and the interior panels - used this "indent" for the 110 volt wire and thermostat wire to the AC also).
There was a double center ceiling panel in the '78 from a previous modification/repair. Fortunately (for me) there exists a large cut out in the area of the black tank vent in the area between the bathroom bulk head void, this cut out allowed for the passage of the 110 wire, the thermostat wire, and the condensate drip line into the wall void in the area of the medicine cabinet/black tank vent.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
New Penguin II installation errors. Did I get ripped? AustinToast Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-03-2012 12:08 AM
need creative ways to build supports for awning teachndad Awnings 4 07-18-2010 06:45 AM
64' rock cover arms ( supports ).. need help campngirl Rock Guards, Segment & Window Protectors 15 07-16-2007 10:50 AM
Gas Line Supports Falling Off gklott LP Gas, Piping, Tanks & Regulators 5 06-23-2005 02:42 PM
Duo Therm Penguin A/C Installation JAG Furnaces, Heaters, Fireplaces & Air Conditioning 1 03-18-2002 10:11 AM
