07-12-2013, 09:53 PM
#21
JT
El Paso
When I installed a Penguin ac in our 73 Over lander I had to use two seals stacked to get enough clearance. Also, if you don't have a working drain you will get water streaks on the exterior skin from condensation drainage. You probably already know this but I have had way too many "wish I had known" moments. When the ac drain clogged on a trip to the Gulf coast we had water dripping inside and out...mama was not happy.
07-12-2013, 11:14 PM
#22
1999 34' Excella
Hillsboro
Yup cups installed beater condensate passed test!
Peace and Blessings..
Channing
WBCCI# 30676
07-13-2013, 01:33 PM
#23
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Originally Posted by cwf
I am replacing the 30 with 50 AMP as son as parts arrive.
Very clean job, congrats!
So how does the unit performs between 12:00 and 15:00?
Curious about the the 30 to 50amps conversion, please start a threat and post some pics. We are seriously considering to do the same.
Keep up the good work!
Still One Nation under GOD
2 chronicles 7:14
07-14-2013, 08:58 PM
#24
1999 34' Excella
Hillsboro
Thanks.
A few pics of today's effort to complete install.
Now, because I can't run through wall I exited the ceiling
Then I stuck to ceiling using sticky back wire tie mounts. I added a sheetmetal screw in center. Then used double wire ties to go around sleeve.
Channing
WBCCI# 30676
07-14-2013, 09:09 PM
#25
1999 34' Excella
Hillsboro
My DW will make wrinkly fabric cover so the black sleeve is hidden.
Will probably velcro
Channing
WBCCI# 30676
07-15-2013, 10:11 AM
#26
1999 34' Excella
Hillsboro
Channing
WBCCI# 30676
07-16-2013, 06:13 PM
#27
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Just wondering where did you got the AC from?
2 chronicles 7:14
07-17-2013, 12:36 PM
#28
1999 34' Excella
Hillsboro
I purchased through Camping World.. I would have purchase through Lewster given the chance.
Channing
WBCCI# 30676
07-18-2013, 07:01 AM
#29
1992 34' Excella
Austin
Devil's advocate comment here:
I hope that much weight that far aft of the axles doesn't cause you separation problems. I always thought that any additional weight aft of the axles is a very bad thing.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
07-18-2013, 03:49 PM
#30
1999 34' Excella
Hillsboro
Get thee behind me satan!
Any extra weight is concern aft or bow loaded. It is about same location AS puts second AC. It is forward of stock from what I have seen. As in this one:
Center mass is about 3' behind rear axle on mine I guess.
But, had to install more AC. Skylight in hallway too big to install there. I had no other options I could find.
Channing
WBCCI# 30676
07-21-2013, 04:50 PM
#31
1999 34' Excella
Hillsboro
Howdy!
We ran the Penguin on the 30 AMP FEED for a couple days. No issues.
After upgrade to 50 AMP feed, 36 hour, no problems.
Condensate line flowing well,
All buttoned up...
The condensate exits inside the water box and out the nice opening AS provided, which is where the water supply enters. Nearly looks stock...
Channing
WBCCI# 30676
