Old 11-04-2012, 08:50 PM   #1
cuyeda's Avatar
Long Beach , California
Penguin II AC, drip pan?
For those who have installed a Penquin II low profile AC, did you install the accessory drip pan?
Reading the owner's installation manual I did not see any mention about installing a drip pan. After wondering about it, I find there is a such a drip pan available for the Penquin II. Part #: 3107688.016 AUXILIARY DRAIN PAN KIT
What is the consensus here regarding an installation. Is it necessary, is it a personal preference, is it worth adding it. Is there problems if the drain tube gets clogged?
1947 Curtis Wright
1958 Traveler 18'
cuyeda is offline   Reply With Quote
Old 11-05-2012, 05:43 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Greetings.
I have been pushing the auxiliary drain kit (the one you mention) over the drain pan for years. I had never seen the drain pan that Airstream uses until I had to replace a roof unit on one................. that was some time ago
The drain kit consists of 2 drain cups that are screwed into the under side of the A/C base pan below the drip holes. They combine with the supplied tubing and plastic 'T' fitting to allow final connection into the Airstream drain tube. A second A/C foam gasket is also supplied to allow the assembly to clear the roof. I believe that Airstream has finally started to use this system over their old, proprietary drain pan system.
I have also heard of a new condensate pump system that Dometic has just come out with. Don't have any details for it but will find out from their tech center this week. PM me if you need more info.
Old 11-05-2012, 06:51 AM   #3
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I followed Lew's advice during my install and used the drip cup system. It works great and doesn't have the inherent weakness of the pan setup.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 11-05-2012, 07:34 PM   #4
cuyeda's Avatar
Thanks for the comments! I received the installation manual for the drip pans! OMG! 2 plastic cups, with a clear hose attached to a Tee connector! I haven't priced it out, but shame on Dometic. It should have been included with the AC regardless if it were used in the installation.
1947 Curtis Wright
1958 Traveler 18'
Old 01-21-2013, 08:57 AM   #5
Tool Hoarder
West , California
I installed them, not sure how well they work cause I havent fired up my ac, but here are a couple pics. It wasnt hard to install. I am just finishing up with installing the condensation line.
ID:	177113   Click image for larger version
marzboy is offline   Reply With Quote
Old 01-21-2013, 09:10 AM   #6
Crusty's Avatar
1992 34' Excella
They work much better than the pan. The hose from the pan tends to get clogged which ultimately results in the water overflowing the pan and down inside the trailer. If the cups drain line happens to get clogged the water overflows out of the cups themselves and it runs down the outside of the trailer.
I'm a fan because I used to deal with a plugged drain line several times a year and the resultant mess cleanup was a real pain. One time the overflowing drain pan even submerged my control circuit board and took it out so I had to buy another one. That can't happen as I see it with the cups.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 01-21-2013, 09:41 AM   #7
cuyeda's Avatar
Thanks for the photos added. Looks like you added the drip cups pre-install of the AC. "Lewster" mentioned above that there is a second foam gasket along with the drip cups to be installed. I already have my AC mounted, and still have the walls open. If needed I can pull the AC off. I have yet to order the drip cup kit.
Question: Is it necessary that the AC come off the roof for the install, and did you run the drip tube inside the walls?
1947 Curtis Wright
1958 Traveler 18'
Old 01-21-2013, 10:00 AM   #8
Tool Hoarder
West , California
I screwed up the first install and had to add the second gasket. You have to remove the ac for the install because you have to add the second gasket. Also I dont think my unit had pre drilled holes for the drip cups. But the unit is much lighter than the oem unit. I am running 1/2" condensation line in the wall down the rib over the front street wheel well. I will post more pics when I am done with the electrical.
Old 01-21-2013, 10:41 AM   #9
lewster's Avatar
There are a couple of holes in the vicinity of the drip cups, but I have found that you need the self-drilling screws in the kit to mount the cups. They go thru the base pan like a hot knife thru butter!
Old 01-21-2013, 12:22 PM   #10
Tool Hoarder
West , California
Thanks lewster i discovered that
Old 06-28-2017, 08:47 AM   #11
Engineer Rich
engineerich's Avatar
1992 35' Airstream 350
San Antonio , Texas
Folks,
My original Domestic A/Cs (25 years old) both died on me...just finished replacing them with new Penguin II's...since it was the way they came, I installed the a/c's as is without any drain line connection, assuming Dometic's design must be to have condensate drain could off the outside the RV. Anyone have any thoughts whether this will be a problem or not?
Warm regards,
Rich
engineerich is offline   Reply With Quote
How do I remove the belly pan? aluminitus Belly Pans & Banana Wraps 19 10-21-2014 10:50 AM
New drip pan Farmer Dan Furnaces, Heaters, Fireplaces & Air Conditioning 2 09-09-2012 08:44 PM
After Market Drip Pan airjeff Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-24-2011 04:11 AM
drip drip drip kepko Sinks, Showers & Toilets 3 09-17-2011 03:36 PM
Need Drain Hose Diameter for Penguin ASAP BrockLives Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-04-2011 05:59 PM
