Old 06-16-2016, 07:30 AM   #15
2016 28' Pendleton
terre haute , Indiana
Sensor located
Yes. The remote sensor for the rear A/C is located under a small round plastic cage to the left of the TV. I removed the cage and discovered that the tip of the sensor is held against the wall with a small plastic clip. I unscrewed that clip and pulled the tip of the sensor out about two inches. Take care not to let the wire and sensor fall back into the cabinet. Now the rear sensor measures the air temp and NOT the wall temp. I think I will drill a small hole in the cage and pull the tip of the sensor through the hole until it is touching only air. Then hold it in place with a little dab of silicone chalking. It is working perfectly with the wire pulled out two inches and hanging in the air.
jcwall is offline   Reply With Quote
Old 06-16-2016, 08:15 AM   #16
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
Does anyone have a picture of the location. I have a 27' Flying Cloud with dual air and I can't tell if it's the same as described here. Thanks in advance.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 06-16-2016, 08:27 AM   #17
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Originally Posted by paiceman View Post
Our 30' FC had the same issue. I moved the thermostat. Not a big deal and partially solved the problem. But, we also raise the temp on the thermostat to compensate for heat build up near the thermostat. In essence fooling the entire system.
Bud
NEED TO CLARIFY. I moved the sensor not the thermostat. On the 30' FC our sensor was up above the TV and on the wall of the refrigerator. Moved it to well below the television and on the same wall, but when I moved the senor put some insulation between the sensor and the refrigerator compartment.
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 06-16-2016, 08:36 AM   #18
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . Since we're picking up our new Pendleton tomorrow , I'm going to show this whole thread to my tech. . .thanks to all for the input. . .regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 06-16-2016, 10:30 PM   #19
Some Guy
djarrett's Avatar
2018 28' Tommy Bahama
Nashville , Tennessee
And there it is. Who knew.
D
The Jarretts
Nashville, Tennessee
2018 27' Tommy Bahama
2015 F250 TV-Petrol
WBCCI # 22342
djarrett is offline   Reply With Quote
OR 090 : OR Unit Rally: Let' er Buck Pendleton Round-up Sept 12-18, 2011 monah WBCCI Rallies & Events 6 09-06-2011 09:20 PM
Win some Pendleton NP Blankets! 47WeeWind Fun & Games 1 09-17-2010 02:39 PM
Small Airsteam needed for Pendleton display 47WeeWind Our Community 31 03-27-2010 04:54 PM
Helen Byam Schwamborn, Camp Pendleton, CA 1946 Red Cross PeeWee Airstream History 5 11-28-2008 08:02 AM
National pendleton roundup Rally buckmaster WBCCI Rallies & Events 0 07-20-2003 09:16 PM
