Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 01-21-2003, 02:49 PM   #1
1985air345
airstreammotorhomes.com
1985air345's Avatar
Profile:  Charleston , West Virginia
Parts for Duo-Therm 900 series furnace?
I have a MH with two Duo-Therm 900 series units. It seems that Duo-Therm (i.e. Dometic) no longer makes furnaces.
1) Is there a good place to get parts for them?
2) Has anyone replaced the Duo-Therm furnaces with another unit? Was size an issue?
I believe that the electronic ignition board is going on both units. How hard is that to change out?
Fred H.
No Airstream Anymore..
Fred's Airstream Archives - Motorhomes
Fred's Airstream Archives - Trailers
1985air345 is offline   Reply With Quote
Old 01-21-2003, 09:49 PM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Fred,
If the furnace hardware is fine you can get new aftermarket controller cards
They are called Dinasouar Boards
You may want to call them as there site has some info in the duo therm 900 and the limitations of their board.
As to size and parts availability in general I will leave that to those with experience
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 01-22-2003, 03:45 PM   #3
1985air345
1985air345's Avatar
I did call Dino Boards and they referred me to R&G Electronics (800) 390-3908. Roy was very helpful. The UIB-S boards are $90. Duo-Therm used 4 different ones so I will need to pull it out and measure it for Roy to send me the right one.
You can upgrade to a Fan-50 at $112 that shuts off the fan when the batteries start to die (the gas/flame already shut off due to low air flow). The UIB-S board will allow the fan to continue to run and completely drain the batteries.
Fred H.
72 Airstream International Furnace parts loechli Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-20-2008 08:17 PM
34.5 Furnace parts charlief1317 Airstream Motorhome Forums 1 01-20-2004 05:59 PM
Suburban Furnace Parts Needed Darryl Parts Archive 0 09-11-2003 08:13 AM
test
