Old 08-28-2009, 10:03 AM   #1
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake , Colorado
Overlander A/C
Yep, been busy this month...
OK, start with the standard Zep scaffold.
Name:	IMG_9791 scaffold up-s.jpg
Unbutton the A/C shroud.
Name:	IMG_9792 a-c shroud-s.jpg
ID:	86237 Click image for larger version
Name:	IMG_9793 top of shroud-s.jpg
The exposed original A/C looks like this. If you remove the entire A/C unit, including its mounting plate, it's too heavy to manage by one person. If you're doing this alone, remove the compressor, which is half the total weight of the A/C--four bolts and cut three copper pipes. There's no helping the possible release of freon--you can't get it off by yourself.
Name:	IMG_9794 bare ac-s.jpg
You can remove just the components and leave the mounting "plate" on the roof. I recommend this approach if your plate is attached all around with solid rivets. Second, if you keep the plate, you have a flat surface to mount your new A/C. You also avoid having to seal up 50-some rivet holes, most of which require Olympics, since the interior skin prevents back side access. On the other hand, the removal of the components will open up some other holes that will need to be sealed.
Note the flanges around the edges of the A/C "plate." These stick up high enough to be unsightly from the ground. You can either bend them down flat onto the top of the plate, cut them off with a sawzall, or, if you're lucky, you can break the spot welds and remove them. If you bend them over flat, you will have a stronger plate.
Anyway, this one was attached with pop rivets so I removed the whole thing. I sure like the looks without an A/C...
Name:	IMG_9795 a-c on scaffold-s.jpg
ID:	86240 Click image for larger version
Name:	IMG_9815 no ac-s.jpg
Whether or not you keep the plate, you MUST construct internal braces that counter the squeeze forces from the bolts used in the modern A/C attachment method. These braces only need to be attached to the outer shell. The internal ceiling skin is not structural so screwing the internal skin to the braces only adds a small amount of support. With only the outside connections, the braces are very stiff--you could do a pullup on them. You, not me. The braces do not need to be attached at the corners--remember, they are mostly there to take compression loads. In this Overlander, there is a rib at the front edge of the opening, so only three pieces of wood were needed.
Name:	IMG_9820 braces detail-s.jpg
ID:	86242 Click image for larger version
Name:	IMG_9823 braces-s.jpg
You can see the pattern of the old plate's perimeter rivet holes here. I used solid rivets where I could get at them and Olypmpics along the street and curb edges.
Name:	IMG_9821 pan outline-s.jpg
ID:	86244 Click image for larger version
Name:	IMG_9824 new a-c in place-s.jpg
Have fun. You can do this by yourself except getting the new A/C up on the scaffold. If the ladders didn't project up above the platform, you could slide the new A/C up the ladder and plop, onto the plank, but not with this scoffold.
Make sure you remember to route the power wire through the braces. Also, I put the drain line in there so that it's accessible--not needed on this model A/C, but some do need it.
Zep
Zep@Charmedquark.net
Old 08-28-2009, 10:07 AM   #2
Kevin245's Avatar
Good job photo documenting your steps Zep. Didn't realize that the new unit footprint is much smaller.
Kevin
William C. Swinney
Old 08-28-2009, 10:10 AM   #3
1973 23' Safari
1977 23' Safari
One note on the seal. It seems way too dense to smash down and conform to the shell curve, but it does. I need to crank the front street side bolt a little to get the white "foot" to touch.
Name:	IMG_9981 a-c seal-s.jpg
Inside is a different story. The shroud won't conform to the ceiling and the controls will be recessed and will be hard to operate. Trimming the shroud would remove the seats for the edge screws, so it's a problem. But the shroud still does a pretty good job without too gross air leaks. Trimming would make it better.
Zep
Old 08-28-2009, 10:39 AM   #4
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
Great thread, Zep. Your old A/C looks practically brand new compared to mine. What was wrong with it? There'll be 47 people PM'ing you to sell them parts off that thing before the sun goes down.
Solve for X, Or is it Y?
www.nesa.org
Air No. 6427
Old 08-28-2009, 10:52 AM   #5
Central , Mississippi
Great post. I will use this info when I stick a second air on our '34.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 08-28-2009, 11:01 AM   #6
1973 23' Safari
1977 23' Safari
Originally Posted by Jim & Susan View Post
Great thread, Zep. Your old A/C looks practically brand new compared to mine. What was wrong with it? There'll be 47 people PM'ing you to sell them parts off that thing before the sun goes down...
I thought it had run out of freon. The first one I did, on the Carvel(http://www.airforums.com/forums/f427...tos-20568.html), didn't have a fill port so I thought this one wouldn't, either. In any event, I had the new A/C, so I proceeded. It turns out it was completely full--the compressor just pooped out even though it was still running. All the other motors and relays worked fine.
All the parts are already gone to the dump, except the relay box. I salvaged all the components from the first one, tried to give them away for a year, and finally dumped them, too.
Zep
Old 08-28-2009, 11:05 AM   #7
Bummer. I was going make you offer on the cover.
www.nesa.org
Air No. 6427
Old 07-14-2010, 04:16 PM   #8
tinsltootsie's Avatar
Great posting of pictures. This shroud looks like what is on our 74, and compressor is not kicking on.
It's the rivets!!!!!
tinsltootsie is offline   Reply With Quote
Old 10-14-2010, 01:49 PM   #9
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
I'm getting ready to do the same job, did you place the 2x4 across the entire center section or just the 14.25 opening?
On completly diffentnote, could the plastic cover be painted silver to match the rest of the air stream?
Silverflames is offline   Reply With Quote
Old 10-14-2010, 02:03 PM   #10
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Hey Roger - so did you miss all the wind and sand on this install?
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 10-14-2010, 02:41 PM   #11
1973 23' Safari
1977 23' Safari
How'd you know I was wishing I was in Albuquerque? BTW, thanks again for the Balloon Festival. Well worth the expensive seats! They were actually cheap at twice the price.
Zep
Old 10-14-2010, 02:51 PM   #12
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I don't see why not. I painted my two-tone blue.
Vaughan
Old 10-15-2010, 08:14 AM   #13
1969 29' Ambassador
Painting AC unit
Yea, that looks real nice. What kind of paint and primer did you use?
Did you have to cut a hole and re-enforce the roof?
Old 10-15-2010, 08:49 AM   #14
1973 23' Safari
1977 23' Safari
Yes, take a look at post #1 in this thread, or for a bit more detail, post #1 here.
Zep
Help ID overlander Walt Stanton 1970 - 1973 Overlander 10 10-17-2009 09:11 PM
73 Overlander bwoodtx Electrical - Systems, Generators, Batteries & Solar 1 07-09-2009 04:43 PM
58 Overlander asta2 Our Community 2 08-26-2006 08:12 PM
'63 26 FT Overlander - value? flombe Trailer Values 3 08-01-2006 10:46 PM
'58 Overlander in need ! scooter 1954 - 1959 Overlander 6 12-29-2002 10:21 AM
