Old 11-12-2009, 09:56 AM   #1
Reno , Nevada
Original Wall Furnace Safe?
Does anybody still utilize the original wall furnaces from late 50's to early 60's airstreams? would like to keep it, but wonder about its safety. If anyone does still use theirs, what is your opinions about the radiant convection heat vs the newer forced air systems?
skittles is offline   Reply With Quote
Old 11-12-2009, 11:10 AM   #2
The forced air systems, whenproperly ducted, keep the water lines from freezing.
The wall heater, does not offer that help.
Old 11-12-2009, 12:42 PM   #3
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
Just the age of the unit raises my concerns. If you decide
to leave it, then I would suggest a disassembly and cleaning.
At that time you may inspect it for rust....
Heat->moisture->rust-> carbon monoxide
kennethowens is offline   Reply With Quote
Old 03-13-2010, 09:57 AM   #4
Reno , Nevada
while gutting trailer, took apart the wall furnace, thoroughly cleaned it, appears to be working good so I'll plan on reinstalling it but will have a CO detector when finished just for peace of mind.a
Old 03-13-2010, 11:20 AM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Since they are simpler without as many parts personally I would be more trusting of an old wall furnace than an old furnace with a blower. Just my opinion. It probably also does not have as many safety features.
Besides a CO detector I also put in a propane and smoke detector.
Old 03-13-2010, 12:48 PM   #6
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I use my original Glen Air heater whenever needed. I too thoroughly inspected and cleaned it as well as the chimney for mud dauber nests since they like to get in there and glog things up. If all appears in order, Light it up and keep and eye on it for the first few hours and as always leave a window cracked open.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 03-13-2010, 01:56 PM   #7
Lothlorian's Avatar
Loganville , Georgia
I use my orginal wall heater. It works great and my trailer is a 73
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 03-13-2010, 02:42 PM   #8
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
We use the original glenair heater in our 61. The disadvantage is the heat comes out several feet above the floor so the floor can be cold. We did thoroughly inspect it, and added a thermal switch in the stack to turn on a small fan to move some air around..
We also have a 6000 btu catalytic heater which we prefer because the heat is closer to the floor and constant instead of cycling.
The plus with either of these heaters is no blower is required to keep them going which is important when boondocking
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Duo-therm wall furnace - 1965 max7 1965 - 1969 Globetrotter 1 08-15-2012 10:53 PM
Original 2 prong cord, how do I make it safe? Jabba Electrical - Systems, Generators, Batteries & Solar 21 07-12-2010 02:01 PM
original interior wall covering Beverly II Upholstery, Blinds, Walls & Interior Finishes 1 10-08-2008 11:14 AM
Digital wall thermostat for A/C and furnace nickcrowhurst Furnaces, Heaters, Fireplaces & Air Conditioning 2 12-21-2004 08:03 AM
Coleman Mo# 3022 Wall Furnace Fishskihike Furnaces, Heaters, Fireplaces & Air Conditioning 0 12-02-2003 07:26 PM
