Old 06-21-2007, 01:51 PM   #1
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
birmingham , Alabama
Images: 26
original a/c leaking in rain
has anyone run into this before? The a/c (old original type) on my 64 overlander leaks after a length of time in the rain (while parked, not on the road).
appears to be dripping off of the fan shaft? Does anyone have pictures or experience that could let me know how the water is traveling from outside to inside down the shaft? not sure if there are shaft seals, grommets, etc that could have gone bad...
thanks.
Doug
59er is offline   Reply With Quote
Old 06-21-2007, 01:56 PM   #2
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
Images: 26
I think its an Armstrong AC.
Doug
Old 06-25-2007, 10:09 AM   #3
thanks.
If it's an original TAC-110 Armstrong, the problem is simple.
That AC took many hours to install, because it came in two halves.
Remove the AC shroud.
Remove the top metal cover of the AC.
You should find a gob of ole "putty tape" sealer around the two copper lines that go thru the roof.
Remove all the old sealer.
Clean the surfaces.
Install new putty tape, except this time, completely cover the putty tape with "vulkem sealer." Don't be stingy with the vulkem. Use lots of it.
That will take care of the leak.
The only other possibilty, however rare, is that the gasket for the fan motor is shot.
That can only be replaced by removing the inside fan blade, and then removing the blower fan motor from top side.
Old 06-26-2007, 10:01 AM   #4
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
Images: 26
Thanks andy.
is the fan motor gasket located between the motor and roof of the camper or is it a gasket inside the fan motor?
thanks again.
Doug
Old 06-26-2007, 12:34 PM   #5
Thanks andy.
thanks again.
The fan motor gasket is between the fan motor housing and the bottom of the AC.
It is necessary to remove the interior fan blade before you can remove the fan motor, since that motor has a dual purpose.
Rarely does that gasket leak, On the other hand the putty tape seal surrounding the two freon lines, "always" leak, in time.
Old 06-26-2007, 05:40 PM   #6
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
There's another leak path
... Rarely does that gasket leak, On the other hand the putty tape seal surrounding the two freon lines, "always" leak, in time.
During the refurb, when my Overlander was sitting still, my original air conditioner never leaked. But after hitting the road for our first trip in pouring rain, it leaked like a sieve. You can read the details at my web site (link in my signature), but the problem was a street-side mounting screw on the top-side half of the unit.
Tom
Old 06-27-2007, 09:36 AM   #7
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
Images: 26
Thanks Andy.
Tom,
I stumbled across your site a while back before this problem....then reviseted it when I remembered something about you redoing the shroud...
great help and great bunch of pictures. makes me not want to take the top cover off of mine to see what the components look like!!!
Doug
Old 06-30-2007, 08:24 PM   #8
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
My 1978 Armstrong A/C is leaking as well during heavy rains. Is the fix the same as the older style A/C units? I tried to take my shroud off today to look in and could not budge it. I took off 4 screws on the top but can not get that shroud to move. It appears to be a top and bottom half. Any ideas?
Many thanks.
Tom
tlavergne is offline   Reply With Quote
Old 07-02-2007, 10:38 AM   #9
Many thanks.
Tom
Tom.
The two piece AC was last used in the 1969 models.
From 1970 on up, the interior part of the AC is only for the controls (sometimes) and air distribution.
Do you have the original 1978 Armstrong AC? Or is it possibly another brand?
Old 07-02-2007, 06:45 PM   #10
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
Andy,
Yes, it is the original air conditioner and is an Armstrong. It says Armstrong 14 by the fan speed control knob. It also has a thermostat on the wall. I have had this trailer for about 6 years and I don't ever recall it leaking until a downpour last fall right before I put it in the barn for the winter.
Tom
'78 Ambassador
Old 07-03-2007, 04:36 AM   #11
TomW's Avatar
1967 26' Overlander
Look on the sides
... I took off 4 screws on the top but can not get that shroud to move. ...
The shroud on my Armstrong unit is secured by four screws on the top and two screws on each side (street & curb sides). The side screws take the place of rivets to hold the vent cover in place. Look closely at the two darker circles near the bottom of this image; They're screw holes:
Tom
Old 07-03-2007, 06:27 AM   #12
1969 31' Sovereign
1951 21' Flying Cloud
Alex , Oklahoma
Air Conditioner
Tom
Tom: I want to thank you for all your information you posted on your web site. I found your sight back in December and printed up a lot of your projects in repair. A couple weeks ago our A/C died, it was the motor. My husband used your A/C repair info like a bible. We thank you with all our heart for sharing your information.
I have a dilemma with my refrigerator. As we just got our AS in Dec and it is a 1969 and the frig is 38 years old. It seems to work great, but the seal was totally gone off the bottom of the bottom door. I found where I can get a new seal for $200.00. My thoughts are if the frig dies by the time I fix it all up I have lost $200.00. I tried to fabricate a seal from an old frig, but the seal it thicker than the original. Any Ideas how to make a temporary seal. I'm not being a tightwad just don't want to spend $200.00 on a frig that may die on our maiden voyage.
Thanks again for your wonderful web sight and thanks to this Forum it has helped us with many projects in getting our 69 back in running order.
1969 Sovereign
1951 Flying Cloud SS#7062
AIR #18751
CJ of Okla is offline   Reply With Quote
Old 07-03-2007, 08:45 AM   #13
Andy,
Tom
'78 Ambassador
The only possibility for that leak, is a bad gasket.
Unfortunately, to replace it, you will have to unbolt the AC and tilt it on it's side.
You will need a 14" X 14" AC gasket.
Old 07-03-2007, 01:53 PM   #14
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
Thanks Andy...one more thing to add to the list. I appreciate your input..
Tom
replacement a/c shroud? roof vents? Dave Cole Furnaces, Heaters, Fireplaces & Air Conditioning 9 12-05-2009 07:00 PM
September get together in the "OCEAN STATE" AirHog Other Rallies & Events 92 09-19-2006 09:00 PM
New Colman A/C (HELP!!!!!!!) TheBigRedTruck Furnaces, Heaters, Fireplaces & Air Conditioning 11 08-24-2002 10:14 PM
a/c theromstat sudden impact Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-09-2002 06:04 PM
Duo Therm Penguin A/C Installation JAG Furnaces, Heaters, Fireplaces & Air Conditioning 1 03-18-2002 10:11 AM
