Old 11-04-2013, 05:39 AM   #1
Bbelk's Avatar
2010 27' FB Classic
Operationally Challenged
I guess I have lived in Texas too long and can’t figure out how heaters work. I have a 2010 27FB Classic. I don’t know if it has a heat pump in the overhead A/C unit. The control panel in the bedroom has four modes. Fan Only, Cool, Heat Pump, and Furnace.
When I turned on the Heat Pump, the furnace came on. How does one run just the heat pump?
Also, I read something about “the auto switchover from heat pump to furnace”, what is that about?
2010 27FB Classic
1989 190 Class B (Sold)
1977 29 Ambassador Land Yacht (Sold)
Bbelk is offline   Reply With Quote
Old 11-04-2013, 06:05 AM   #2
dznf0g's Avatar
Oswego , Illinois
How cold was it when the furnace came on instead of the HP? The heat pump will not run below about 36 - 38* or so. The auto switchover is reset (if the 12v has been disconnected by batt removal or cutoff switch) by turning off the tstat, holding down the top and bottom buttons then switching the tstat on. You should see "FF" on the screen.
The HP should come on (after a 2 minute delay sometimes) when heat pump is selected and it is above 36 - 38*.
-Rich-
Old 11-04-2013, 09:01 AM   #3
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Rich,
Would you tell us more about the Auto Switchover you mentioned above? I don't know about it and would like learn. Thanks.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 11-04-2013, 09:30 AM   #4
dznf0g's Avatar
Oswego , Illinois
My comments apply to the 5 button CCC and not the newer CCC2, which is a confusing bugger.
If you turn off the switch on the bottom of the CCC and hold down the top and bottom button on the face of the unit WHILE switching on the black switch on the bottom, you will see "FF" in the display until you release the buttons.
Assuming you have a heat pump and it is wired correctly, somewhere around the mid 30s* outside temp, the heat pump will switch over to the furnace automatically. In the morning or when temps rise again to that threshold, the system will switch back to heat pump.
Anytime 12V is removed from the CCC thermostat (batt removal or shutting off the cutoff switch at the power center, the reprogramming steps must be taken for the auto switchover to work. You must be in the HP mode for this to work. When the switch to furnace occurs, you will see both "aux. heat" and "heat pump" on the LCD display.
This is explained in manual....but I can't seem to find a pdf online.
-Rich-
Old 11-04-2013, 09:37 AM   #5
dznf0g's Avatar
Oswego , Illinois
Found it. Check page 7...however the programing instructions are missing....use my instructions listed above for programming.
Dometic Comfort-Control-Center_operation_EN.pdf
-Rich-
Old 11-04-2013, 11:16 AM   #6
Bbelk's Avatar
2010 27' FB Classic
Thank you. This has been most helpful.
2010 27FB Classic
Old 11-06-2013, 07:33 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Peace and Blessings..
Channing
WBCCI# 30676
