Old 08-27-2011, 12:33 PM   #1
PhiDor's Avatar
2007 34' Classic S/O
The Villages , Florida
One AC not working
I have 2007 34 Classic w/2 AC's - DuoTherm Penguins.
The rear one works fine on 30 amps, (thank the Lord) but the compressor on the one in front (looks bigger) will not start. The fan works fine, but as soon as i ask for cooling it just groans for a second and then stays on fan. It will continue to try to start, but it doesn't. It was working a few days ago. I only run one unit on cool at a time on 30 amps. I have shut off the refrigerator electric and water heater electric and that doesn't help.
Any suggestions?
Phil & Doris Drugge
[COLOR="Red"]WBCCI #4941
"Jerry and our Amazing Dream Stream"
PhiDor is offline   Reply With Quote
Old 08-29-2011, 01:16 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
The front unit needs service. Either it needs a new start capacitor or there's something more seriously wrong.
Old 08-29-2011, 02:46 PM   #3
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Any suggestions?
How does the switching work between forward and rear? We all know 30 amps does not get it for dual roof air.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 08-30-2011, 06:21 PM   #4
PhiDor's Avatar
One not working
The AC's are on a panel that allows you to run one or both. You can have 2 AC's running. or one fan & 1 AC or 2 Fans only. I'm only trying to run one on 30 amps. It is quite possible after checking the circuit voltage that there was too much of a drop at the campground. It went down to 11o volts from 120v.
I think the front one is 15000 btu's and the rear 13,500 btu's.
When I get home I'll check it out again. I have a 120v 30 amp circuit only for the trailer.
I'll let you know what happens. Going home tomorrow I think.
Thanks for your comments.
Phil & Doris Drugge
Humphrey gas light not working properly bmklawt LP Gas, Piping, Tanks & Regulators 6 12-05-2011 09:58 AM
PAR pump not working ckbailey97 Water Heaters, Filters & Pumps 9 07-14-2011 05:01 PM
Electric working with battery not with 110 TX_DB Electrical - Systems, Generators, Batteries & Solar 11 04-24-2011 07:19 PM
License plate light not working worksology Lights - Interior & Exterior 7 04-08-2011 05:05 AM
Docking Lights not working 396 XL Torpedo Family Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 13 02-04-2011 02:10 AM
