Old 01-01-2017, 10:25 AM   #1
jonathan
1969 23' Safari
Homestead , Florida
on demand water heater
Hi, what is the best "on demand water heater I can fit for my 1969 23' Safar
jonnyregis is offline   Reply With Quote
Old 01-01-2017, 11:59 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
One of several past threads,
http://www.airforums.com/forums/f445...rs-131393.html
MICHAEL
Old 01-01-2017, 01:00 PM   #3
2022 25' Flying Cloud
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
I put an RV500 in the 2012 25FB and just loved it! You do have to open the wall a bit to fit. The RV500 was great. I put an RV550 in our 2015 Bunk before we took our first trip. The RV550 is a big disappointment. You have to constantly adjust the external temp control depending on outside temps. We also could not get it to adjust to lower temps when showering until I called Precision Temp and complained. They said to turn the sink hot water on to a pencil size stream which allows us to regulate the temps pretty good. I was offered to test a new pre-production unit that is supposed to be more like the old RV500 but decided the sink on trick worked well enough. I would not trailer without an instant on constant hot water system. Check with Precision Temp and make sure you get the latest model not an RV550. You will love it.
2022 25RBT FC, 50A Dual AC, Awning Package, 270W Solar, Convection Microwave. Ceramic Coat, Grand Lounge, 3" Lift, 16" Michelin RIBs, Multiplus II, Battleborn 400A, MPPT 100/50, Orion-TR 30, EasyStart (2), Easy Touch, AirKrafters jenRack, Onan 2500i, Truma Aquago Confort, Starlink, Pepwave, Parsec
2012FB is offline   Reply With Quote
Report on Marey On Demand Tankless Hot Water Heater Collapso LP Gas, Piping, Tanks & Regulators 5 12-08-2012 05:44 PM
Atwood on-demand water heater svanpelt Plumbing - Systems & Fixtures 1 11-28-2012 10:34 PM
On Demand Water Heater? codybear Water Heaters, Filters & Pumps 4 06-04-2011 10:27 AM
Small Electric on-demand water heater and a 20A plug Globie64 Electrical - Systems, Generators, Batteries & Solar 5 04-14-2011 07:49 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
