Old 11-06-2015, 06:49 AM   #1
Kathys quilt's Avatar
1967 30' Sovereign
Nauvoo , Alabama
Old furnace/ac
Restoring a 67 30' Sovereing and my wife wants as much original stuff as possible. The furnace has been disconected but is there. An ugly wall gas unit is on the wall of the furnace cabinet cutting off the door to the unit from that view. When I look into the other, larger door, I see no controls to work with if I reconnect. Are they missing or do you get to them through the blocked smaller front door? Am I graskping straws or not in wanting to get the old furnace working again? Next comes the AC.
It blows lots of air (fan great) but it is just a little cool. Needs chargeing or a new compressor. Do yall feel it is worth trying to save or give it up?
If I can keep it, do I have to have a shroud even though the air flowfins are some what protected by the old vents off an old shroud.? Once more, Thanks for any help or ideas.
Kathys quilt is offline   Reply With Quote
Old 11-06-2015, 09:06 AM   #2
1974 Argosy 20
Kooskia , Idaho
The old furnace is 48 years old. Suburban furnaces of that era were subject to recalls and those recall parts are no longer available. Few parts of any type are available. The safety issues involved with an old furnace are such that it is best if you simply get a new one. Take the "ugly gas wall unit" out and pitch it also. Then you can get at the space for the original furnace. Sizes have changed some on Suburban furnaces but the new ones are smaller than the old, so you probably can find space to put a newer unit in. Unless you are planning on travel in very cold weather, I would not put one larger than 24,000 btuh in, especially in your mild climate.
There are many advocates of repairing/restoring the original AC unit, probably an Armstrong. I am not one of those advocates. Yes, it can be done but it is going to be hard to find someone willing to work on it in any event. Searching for parts, and working on a 48 year old AC unit takes a special type of AC mechanic or person up to the challenge. The end result will probably be a more expensive unit than replacement and it still will be 48 years old. You could call around to see if anyone in your area would take the job on, but I am betting that they all will say no thanks.
And I am sure that others here will say it is easy peasy to repair an old Armstrong and advocate doing it. Ultimately it will be your choice as to what to do with it.
The furnace is a life safety issue, the AC is a comfort, cost, and hassle issue but not a danger.
New Circuit Board for Dometic 13,500 Penguin heat pump old p/n 3106682.036 old p/n 3311557000. Shayne50 Airstream Classifieds 0 07-28-2015 08:29 PM
towing an old trailer with an old truck tworavens Tow Vehicles 9 04-06-2014 05:37 AM
Old, old, old airconditioner removal bilby05 Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-17-2012 04:19 PM
Tires- How old is too old?? rbr Tires 20 08-09-2009 09:26 AM
I had a fun day (pictures) Old trailers and old stuff RichardT Off Topic Forum 11 03-13-2005 03:49 AM
