Old 03-26-2010, 07:06 PM   #1
1978 28' Ambassador
Savannah , Georgia
OK, so how do you open the A/C shroud?
Would really like to go one day without breaking something. Today removed what was left of the four rusted bolts on the top of the A/C shroud. Tried to lift the top part off and other than a nasty crack/split it did not budge. Used a putty knife around most of the edges. Got one corner to lift up slightly. Are these two pieces riveted together? Thought the top just lifts off once the bolts were removed.
Believe this is the original Armstrong A/C. Found a replacement shroud, but have not tested the A/C on 30 amp. If I can spearate the two pieces, will patch the cracks and if A/C works this summer will spring for new shroud. If A/C fails, will have to replace whole unit anyway. Thanks. Jack
p.s. Too late/dark to take a picture tonight, but will add one tomorrow
Skamper1 is offline   Reply With Quote
Old 03-26-2010, 09:09 PM   #2
The AC shroud is in 2 pieces.
The seam is covered by the metal molding that goes around the center.
Sometimes, some Vulkem was applied to the very bottom of the shround, to hold it against the roof.
Not a good idea, but it was done anyways.
Old 03-26-2010, 10:43 PM   #3
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
When working on our shroud (getting dirt and small acumulation out) there were four screws that held it in place...there was no glue or anything like Andy mentions on this one and it just raises right up in a such and such manner.
ID:	98851   Click image for larger version
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 03-27-2010, 07:05 AM   #4
1978 28' Ambassador
Savannah , Georgia
Took a picture. So the shroud is in two pieces, but they are riveted together to make one complete shroud? When I remove the four bolts on top of the shroud the entire should should lift off of the AC in one piece?? The base of my shroud is vulkemed all around to the roof of my AS. If it is supposed to lift off guess I need to remove the vulkem. You can see where the front part is separated. I assume I managed to release some of the rivets. Thanks. Jack
Old 03-27-2010, 07:22 AM   #5
Attachment 98859
Suggestion.
Use the ladder on the door side of the trailer.
That will allow you to use the awning for additional security against slipping.
Old 03-27-2010, 08:08 AM   #6
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
Skamper1...Glad you brought this up. I have been trying to get mine apart for years with no success. It works great but I would love to get in and clean it. So if I understand correctly the shroud should come off as one unit from the roof the trailer...yes?
"Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid." -- Frank Zappa
tlavergne is offline   Reply With Quote
Old 03-27-2010, 08:48 AM   #7
1978 28' Ambassador
Savannah , Georgia
Andy: The ladder you see is one of two that are tied together. The 2"x4" shown are part of a platform I made to distribute my weight. Saw the idea here. Makes it easier to work on all the vents and antenna.
Now the question: If I loosen all the old vulkem around the bottom of the shroud then the shroud should lift off in one piece?
Thanks. Jack
Old 03-27-2010, 09:43 AM   #8
Thanks. Jack
Jack.
Yes, but you must also remove the 4 screws from the very top.
Old 03-27-2010, 09:45 AM   #9
The 1973 thru 1979 AC shrouds, are 2 piece.
Removing the metal molding will reveal the 2 halfs.
Old 03-27-2010, 09:54 AM   #10
1980 31' Excella II
Drummond Island , Michigan
Far as I can tell you cannot easily take the shroud off in one piece. The easiest way to service the unit is to drill the pop rivets out around the belt line or equator of the shroud and separate the two pieces. You would think that this should have been assembled originally with screws or some other type of removable fastner. But then again it is easier to drill out pop rivets rather than rusty corroded screws. If your unit works it will be worth the effort to save the shroud. If the A/C is not working or needs service it is pretty expensive because it used the old non-environmentally acceptable and very efficient refridgerant. The old refridgerant will have to be safely recovered and then replaced and what ever needs fixing, fixed. You will then have a 42 year old repaired A/C that may fail again with no guarantee for not much less than what a new A/C unit with a guarantee costs. If you replace the A/C check out the threads in the forums for advice. A/S have curved tops and the available A/C units are built to be installed on flat sob roofs. Recently a freind of mine had his replaced on a '74 by an Airstream dealer and they did not put the proper spacer/supports in and crushed the innner and outer skins together which created a very nice place for water to collect and enter the trailer. Have fun!
Ahzmyrah is offline   Reply With Quote
Old 03-27-2010, 10:10 AM   #11
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
The A/C shroud on our "78" Ambassador is badly broken. How hard is it to find a replacement schroud? Do they make new ones? Thanks!
TAC PA-5
Roadrunner is offline   Reply With Quote
Old 03-27-2010, 12:54 PM   #12
1978 28' Ambassador
Savannah , Georgia
According to the forums and google search, only place I have found them is InLandRV. Would put in price, but understand that is frowned upon here.
Talk about rusted screws? Every dang one of mine have welded themselves to the AS. Guess that is to be expected since the "sweetheart" sat in the marsh for 8 years.
Screw extractor, penetrating oil, heat, blood, sweat and swearwords don't seem to budge them. Finally have resorted to cold chiesel to try to back them back off or if all else fails, pop their heads. Andy suggested I remove the four bolts that held the shroud in place....visegrips grabbed ahold to what was left of the rusted heads! At least they came out!
Will try to remove shroud tomorrow. Thanks. Jack
Old 03-27-2010, 01:59 PM   #13
1980 31' Excella II
The screws on top are tough to get out. Fortunately two came out with screwdriver that fit the screw head pretty closely the screwdriver had a square shank that I used a wrench on to turn the driver. The other two well...the wrench on the screwdriver worked too good, snapped one head off and ruined the head on the other. That's when the visegrips came out, should have used them in the first place. Replaced the screws with stainless steel screws and washers and coated the threads with anti-seize compound.
Old 05-11-2010, 08:44 PM   #14
zipman's Avatar
Tuscaloosa , Alabama
Help a dummy out. If I want to clean the coils, do I need to remove the upper part of the shroud? If so, do I still need to remove the 4 bolts? What is the best way to clean the coils? Is the filter located in the upper shroud? Should you clean or replace the filter?
Ken F
zipman is offline   Reply With Quote
New a/c shroud!! Chas Furnaces, Heaters, Fireplaces & Air Conditioning 18 01-31-2016 03:26 PM
AC Shroud Help stoney1939 1966 Overlander 5 08-17-2014 05:23 AM
Shroud for '71 to 76 A/C SPasquale Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-17-2010 05:48 PM
New Shroud for AC Engtech05 Furnaces, Heaters, Fireplaces & Air Conditioning 8 09-03-2009 03:11 PM
Shroud Necessary?? The Flintstones Furnaces, Heaters, Fireplaces & Air Conditioning 11 06-07-2009 05:15 PM
