Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 02-06-2008, 08:43 AM   #1
Crusty's Avatar
Profile:  1992 34' Excella
Ok, I need help ...
I've figured out how to remove my Suburban NT-35 furnace from it's mounting in the trailer, but I can't figure out how to get the furnace guts out of the case in order to replace the fan motor.
Somebody give me a clue ... please.
Crusty
"If you come to a fork in the road, take it."
Austin, TX "Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 02-06-2008, 10:56 AM   #2
Always Airstreaming!
rickandsandi's Avatar
Profile:  2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Crusty-
They have a fantastic web site, check it out:
Suburban > Service > RV Water Heaters > Questions & Answers
Rick
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is online now   Reply With Quote
Old 02-07-2008, 06:15 AM   #3
Crusty's Avatar
I guess it's fantastic but it was no help whatsoever.
Once again - Does anyone know how to withdraw the internal components from the case of a Suburban NT-35 furnace to get access in order to change the fan motor?
Crusty
Old 02-07-2008, 07:33 AM   #4
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
Yes.
Remove the outer vent cover, then remove the one or two phillips screws that hold the combustion tubes in place.
next, remove the inner cover, then unhook the lp line, and 12v wires to the fan. After that, unscrew the 2 screws in the base of the inner assembly, and remove the inner furnace assembly.
(No Longer at Inland RV)
Old 02-07-2008, 10:19 AM   #5
Profile:  2007 30' Classic
Leonardtown , Maryland
This web site may help. Under furnaces the NT-35 is listed with two manuals.
Service Documents
Good luck
dale
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 02-07-2008, 10:39 AM   #6
jdalrymple's Avatar
Profile:  1981 31' International
Siloam Springs , Arkansas
Just a few screws, the propane line, and the wiring harness is all I removed or unhooked. I was able to leave the case and duct work mounted in the trailer, and slide the combustion chamber and fan assembly out of the case, toward the end opposite the fan.
Jeff & Cindy
Remi & Hunter
'81 International 31'CB
WBCCI #7026 Air #17054
"Fus-A-Lodge"
Old 02-07-2008, 01:07 PM   #7
Crusty's Avatar
Wow - ask and ye shall receive!
Thanks all - I think I see some warmer nights in my future.
Crusty
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
