11-03-2014, 06:46 PM
1970 27' Overlander
Tryon
, North Carolina
NT30SP will not fire
Hi again all!
I have just plumbed and wired my new to me furnace. When I turn the thermostat to a temp higher than room temp, I hear it click, then the fan comes on and then the igniter starts sparking (I know this because I can see it in the peep window). But there is no heat. I do not smell gas either (good, right?) So, what am I doing wrong or what is my problem with this furnace? Where do I go from here?
Thank you in advance for the schooling!
Al
11-03-2014, 07:24 PM
1974 Argosy 20
Kooskia
, Idaho
"new to me furnace"? Do you mean it is a used furnace? Do you know for sure it worked when you got it?
If it is sparking, but not lighting, it sounds like there is either no gas, or the electric gas valve is not opening. That could be a bunch of things, from defective valve, to circuit board issues, to electrical issues to the gas valve itself.
You are sure you have propane, that is it is on and other appliances are working? Also, sometimes it takes a bit of time for the propane to get to the furnace on a new install. I assume you have tried it several times.
11-03-2014, 07:25 PM
1981 31' Excella II
New Market
, Alabama
My guess is you don't have propane going to it. A valve is closed or pipe is kinked etc. Does the stove work? Do you have the intake blocked?
Perry
11-03-2014, 07:26 PM
1974 Argosy 20
Kooskia
, Idaho
Also, on Airstreams of that era, there was a shut off valve for each appliance, including the furnace. Are you sure that valve is on?
11-03-2014, 08:13 PM
1970 27' Overlander
Tryon
, North Carolina
Thank you for the responses! The cook top works great. I cannot find a shutoff valve under the trailer. I removed the original furnace as it was rusted through.
11-03-2014, 08:14 PM
1970 27' Overlander
Tryon
, North Carolina
It is a used furnace. The PO of the furnace said it worked before he took it out of his RV.
11-03-2014, 08:18 PM
1970 27' Overlander
Tryon
, North Carolina
I have tried to fire it up a few times. Should I loosen the gas at the shutoff valve? I did have to cap the furnace line when I renovated and reinstalled the cook top as it was leaking. What step by step should I take from here?
11-05-2014, 10:32 AM
1974 Argosy 20
Kooskia
, Idaho
The first thing to try is to loosen the gas fitting to the furnace and determine that you actually have gas there.
A used furnace is always suspicious in my mind. When things sit they tend to go bad, and so the "worked the last time I used it" may be of no value.
11-05-2014, 01:54 PM
1981 31' Excella II
New Market
, Alabama
So why would one take a running furnace out of an RV?
Perry
11-05-2014, 01:58 PM
2007 22' International CCD
Corona
Possibly the same reason I took an Atwood 6 gallon hot water heater out that was working perfectly. To install a better tankless one.
Agreed, unless you actually see it work, I'd be a bit suspicious too.
11-05-2014, 07:19 PM
1970 27' Overlander
Tryon
, North Carolina
It was parted out of a wrecked trailer. I have 50 bucks in a furnace vs. a 700+ new furnace. Couple parts and I'm up and running and I learned something about furnaces. As I go down the checklist from the owners manual, looks like a gas valve. Will know more tomorrow.
11-05-2014, 10:27 PM
Corona
Best part is when you are done getting it working you will understand how it works in detail...and can fix it quickly.
11-06-2014, 07:23 AM
1981 31' Excella II
New Market
, Alabama
I replaced mine because the cost of fixing it was getting to be a time waster and when I want it to work it needs to work. Mine worked one day and not the next.
Perry
11-10-2014, 04:17 PM
1970 27' Overlander
Tryon
, North Carolina
New gas valve and she works like a jewel! Woo hooo!
