Old 04-26-2003, 07:09 PM   #1
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
NT30 Suburban, slight problem
While using our furnace 2 weeks ago the wife noticed a burning rubber smell. It seems to appear after the furnace has been running for 45 minutes or so. I did see what appeared to be a rubber tube or maybe it is a gasket loop sticking out of the left side. Anyone know what this might be? My guess is some kind of gasket that has come loose. I have never had the furnace front off, any tips on removing it, before I try and break it?
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 04-26-2003, 07:16 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Pick,
The front of the furnace itself is easily removed by undoing the 2 screw that are tab mouted on the left and right sides.
If the furnace is original, the smell could be the exaust tube to the outside world failing. This would be very dangerous if it is the case, as you can get co2 poisoning real fast. For a couple of years they used rubber tubes and they were a weak spot.
The furnace is usally held to the floor with 2 screws that are accessable once you pull the front cover. The center screw in the outside plate is one of the attachment points, the screw goes on forever. The 4 outer screws on the outside hold the outer plate to the skin.
3 screws, power and gas disconnect and it should come out.
You may have to work it a bit if the tubes are all metal as they tend to rust together, but if they are rubber it will come out eaiser. Good Luck.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 19 02-08-2010 10:05 PM
Info Request from Suburban Owners MileHigh On The Road... 32 01-28-2004 06:16 PM
Suburban 3rd seat TomW On The Road... 1 01-21-2004 05:04 PM
Argosy water fill problem mcneon Argosy Motorhomes 1 10-09-2003 05:30 AM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
