Old 12-20-2012, 09:45 AM   #1
1986 Argosy
ozark , Arkansas
NT16F furnace repair question
If you have any information, is there gas valves and switch available for this furnace, NT16F. If you know where I can find those parts, please let me know. Thanks.
gbarnes is offline   Reply With Quote
Old 12-20-2012, 10:40 AM   #2
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
How old is the unit, and what condition is the heat exchanger and burner.
Worked on number of these, and are always concerned about safety.
Check it over carefully before investing any money into it.
Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
Jim in Pima is offline   Reply With Quote
Old 12-20-2012, 10:50 AM   #3
1974 Argosy 28
Originally Posted by gbarnes View Post
If you have any information as to where we can get a gas valve and an air flow switch for an 1976 Argosy furnace, we would appreciate it.
Myself and another guy who is an RV tech and Suburban dealer have looked without success for a retrofit solution for that gas valve. I had to find another heater from this era and salvage the gas valve from it. You may be better off with a new heater anyway.
inTransit is offline   Reply With Quote
Old 12-20-2012, 10:56 AM   #4
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I HAD a NT 16F in my 71 GT. I stuck a borescope inside the burner can and it scared me. Full of tiny pinholes from rust. Threw it away and bought a NT20 forced air unit out of a wrecked late model SOB for 100 dollars. It bench checked perfect. I'll bet it was only used a time or two before the trailer was rear ended.
Old 12-20-2012, 11:37 AM   #5
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
You can get a replacement furnace pretty cheap on ebay. Do an ebay search for:
rv furnace. There's one listed for $319 - SUBURBAN 16,000 BTU RV FURNACE NT-16SE TRAILER SMALL HEATER FOR CAMPER LP GAS.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 12-20-2012, 05:32 PM   #6
1986 Argosy
ozark , Arkansas
Serface rust on heat exchanger. no holes. burner was cleaned. 1976
Old 12-20-2012, 06:57 PM   #7
1974 Argosy 20
Kooskia , Idaho
Does the crossover tube which connects the combustion blower wheel to the combustion chamber have a red stripe on it? If it does and is in good condition things are fairly OK, but if it is the original black one, they crack and were subject to recall by Suburban years ago. The recall replacement tube has a red stipe on it. Suburban no longer has the recall parts nor do they support any service items for their furnaces which use pilot lights.
Just something else to think about.
Rear bumper repair - 2000 classic grumpy Bumpers & Bumper Storage 4 04-03-2012 04:19 AM
Duo-therm and furnace question... NoMoSOBs Furnaces, Heaters, Fireplaces & Air Conditioning 13 10-21-2011 09:17 AM
Furnace ducting question? Mrcrowley Winter Living 6 08-26-2011 07:51 PM
Need advice on furnace. SilverRanger Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-28-2011 03:47 PM
'64 safari steps repair question Homewrecker Steps 4 03-14-2011 03:01 AM
