Old 12-23-2009, 01:30 PM   #1
69SafariDude
1969 23' Safari
Indianola , Washington
NT-22A Fan Noise
I have a 69 Safari with an NT-22A. The fan motor has gotten very noisy and I've replaced the nose bearing (had a friend who is a machinist make me one) and it still squeals, although it is intermittent. I'd like to find a replacement motor but can't find parts. I see from threads that many people have replaced these furnaces due to the recall issue, and the fact that they are super old at this point. Any chance someone would sell me the fan motor from their old unit?
I use a CO monitor and I've inspected the crossover hose (it's fine, looks like it was probably replaced) and the heat exchanger still looks to be in good shape (miraculously), so I'd like to avoid replacement if possible.
Thanks!
David
mandonaut is offline   Reply With Quote
Old 12-23-2009, 02:30 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I have a N16 furnace down in my basement that I removed from my 71 21' Globetrotter. I was planning on reusing it but have now replaced it. I brought a borescope home from work and looked at the internals of the burner chamber and what I saw there convinced me to replace the entire unit. It was severely rusted with small pinholes that were not visible from the outside, the wiring insulation was non existent in places. The blower motor bearing (bushing) were also worn out and squealed when I put power to it.
You could try to rebuild it but it was not worth the safety hazard to me so I just replaced it with a modern NT20 unit.
Old 12-26-2009, 02:11 PM   #3
69SafariDude
1969 23' Safari
Thanks all! I just got a used NT-22 from a generous member with a fan motor that works great!
Old 12-26-2009, 02:17 PM   #4
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Good deal! We Spring and Summer in Suquamish; we'll have to get together; Rob at the store is a good friend of mine.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 12-26-2009, 06:24 PM   #5
69SafariDude
1969 23' Safari
look me up
Sure, look me up when you come. My name is David Smith and I live at Wise Acres. Seeya in the spring!
fan motor, furnace, parts
Refrig fan noise FIXED...really dtbw Refrigerators 264 01-31-2018 05:15 AM
Motor / fan noise realpank Argosy Motorhomes 4 02-06-2010 08:56 AM
Dometic cooling fan noise dlb435 Refrigerators 10 06-24-2009 07:48 AM
Fan noise flyguy 2005 and newer - Bambi all models 2 07-29-2007 12:00 AM
Fantastic fan noise oxblood Roof Vents, Skylights & Fans 5 03-16-2005 12:28 PM
