Old 04-11-2011, 07:34 PM   #1
tracker
tracker's Avatar
1969 23' Safari
crescent city , California
nt-22A cabinet
Can anyone tell me how to remove the cabinet part of my NT-22A furnance? I was able to remove the furnance from the cabinet but after removing three anchoring screws the cabinet still will not come out.It seems to still be anchored by something around the wheel well. Ideas?
tracker is offline   Reply With Quote
Old 04-11-2011, 08:07 PM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Seems like I had to scratch my head a few times when I removed the Nt-22 from my 68 Trade Wind. I think I still have the cabinet in the shop, I"ll check in the morning for signs of where it was attached and let you know.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 04-11-2011, 09:23 PM   #3
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
I think it's welded, soldered or something at the base. But I replaced my 22A with a 30 Sp and kept the old casing and just slide the new unit into the frame.
Has to cut the front cover with metal snips as the gas line fed from the right instead of the left.
On the other hand if you want it out of there a small sledge hammer and a prybar may do the job.
RichHog is offline   Reply With Quote
Old 04-13-2011, 09:54 AM   #4
tracker
tracker's Avatar
1969 23' Safari
Thanks guys I want to save the cabinet and reuse it but it has to come out so i can do some floor repair under it so it needs to come out in one piece.
Any refinished oak cabinet pictures out there? mikeandnora Cabinets, Counter Tops & Furnishings 18 09-01-2011 11:10 PM
Cabinet latches sawyerpoint Cabinets, Counter Tops & Furnishings 3 06-24-2011 09:08 AM
2009 Loose Cabinet Screws tmarquis Cabinets, Counter Tops & Furnishings 18 04-11-2011 04:08 PM
Rebuilding Cabinet Doors webspinner Cabinets, Counter Tops & Furnishings 14 03-28-2011 10:29 PM
flip up cabinet springs:? billiards Cabinets, Counter Tops & Furnishings 4 01-24-2011 06:25 AM
