Looking for some experienced info on the pilot light jet. I am trying to get my Suburban NT 17 to fire up. when I took it out it looks like it hasn't been used much in its 39 years. I hooked the pilot jet up to a vacume pump and it will just sit steady at 60 lbs. I can't even see where a hole would be for the gas to get through. Does any one know if these are replaceable or if they can be cleaned?
How about a picture of your vacuum pump set up and the orifice. It odd that you are seeing 60 pounds when vacuum is measured in inches and is maxed out at 30 inches.
__________________ WBCCI 12156 AIR 3144 WACHUNG TAC NJ6 2004 Excursion 4x4 1991 34 ft. Excella +220,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Those orifices have a couple of holes in them too small to clean. In the past I have been able to get the from my local heating repair person so they must be fairly common.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Soak the orifice in "Lime away" for a couple of days.
Or, place it in a "ultrasonic" jewelry cleaner for a few minutes.
Thanks for the replies. I used an inexpensive vacuum tool for bleeding brakes and testing vacuum hoses. I pumped it up to 60 and it stayed. Rick, I looked all over, they must be real small holes.
Andy Im going to snatch my wifes jewlery cleaner when she's not looking and try that. Can't find a repair shop open till Mon. anyway.
Let you know.
Andy that was BRILLIANT!! Have a Bartles and James on me. Took about 30 min. in there and now I can see the 2 holes. I'm going to put it together and test.
Thanks!!!
Brian
Thanks!!!
Brian
Your welcome.
Many fixes for Airstream problems are simple.
Then we read the instructions, and mess it up.
The bottom line however, did it fix the furnace problem, or at least that one?
Christmas shopping interupted getting it all back in. I did get the lines back together and tested it using a can of butane and it lit right up. Next I want to get some high temp chaulking to seal the chamber before loading it back in.
Michele doesn't need to know how I fixed it.
