Old 01-07-2014, 03:05 PM   #183
2004 30' Classic
Hillsborough , New Jersey
not enough heat in the back
Jammer, I don't know if your question has been fully answered since I didn't read all the comments, but here is what I did on my 2004 Classic 30 footer.
In order to cut down on the turbulence inside the ducts I stretched and straightened out the ducts as much as I could. I then wrapped most of them with reflective 1/2 inch insulation, while keeping them as close as possible to each other to minimize heat loss.
In the bedroom I opened the vent and slid a aluminum tube that just fit INSIDE the ductwork as far as I could. This cut down on the turbulance, gave a straighter flow of the air and has increased the temperature in the bedroom noticeably. Wolf146
wolf146 is offline   Reply With Quote
Old 01-23-2017, 01:34 AM   #184
2016 FC27FB - F350 2017
2016 27' Flying Cloud
Fort Lauderdale , Florida
Send a message via Skype™ to Vitaver
We face the same situation on our 2016 FC27FB. I admit I did not read every entry into this thread but will run to offer what works for us on sub zero temps.
Two Voronado ceramic space heaters: one under dinette, one in the opposite side, in the bedroom behind the head's bulkhead, in the corner. The first one in max (1.5KW) the second on half that wattage. Both thermostats set at 70F
Furnace thermostat at 50F
The goals is to save on propane, as we get unlimited juice from the city but propane is not. Auto switch regulator on top of propanes.
2 heat lamps under the tanks, surrounded by boards and thick styrofoam glued/screwed to it. Lamps not close to the edges to avoid burning/melting the styrofoam.
Head sink always dripping. Gray tank valve open.
Hot air has it's own ideas, regardless of where we point it at: it rises. To reach even the thermostat at the Furnace/AC control, it will have to first heat the top, including the very cold interior skin of the AS. Should the temp at that point reach 50 F or below, the furnace is my fallback freeze preventer.
Heat starts rising from the lamps below the belly. Then from the two Voronado, Furnace is the last resort but I figure before temp reaches 50F at that point, is has to be above freezing at the lowest point: the pipes and tank. So far it worked.
I tried cheap $24 heaters from Lowes and expensive $500 Dyson. The cheap ones worry me about fires or failure (one stopped working completely). The big Dyson is challenging to store and (contrary to mos lucky other users) did not follow the thermostat settings, so I brought it home where the esthetic value plays a more important role. Dyson is great, I have the V8 at the AS, and LOVE IT! Hangs right behind the bedroom TV.
2016 FC27FB - 2017 F350 Platinum 6.7L Diesel, Crew Cab. - 2017 Audi A7S - 2014 Land Rover LR4 HSE
Accuracy International + SB, various.
GSD Sigrid - Fort Lauderdale, FL and Silverthorne, CO
Vitaver is offline   Reply With Quote
furnace tuning
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
The Heat is ON!! GlenCoombe Mechanics Corner - Engines, Transmission & More... 5 10-09-2005 03:48 PM
Odd back-to-back eBay auctions .... summerkid Trailer Values 5 09-12-2005 12:34 PM
need heat whistler Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-07-2004 01:32 PM
