Old 04-04-2016, 11:16 AM   #1
2005 31' Classic
Pleasant Plains , Illinois
Noisy Air Conditioner
I have a single, Penguin, 13.5K btu air/heat pump that's become noisy. It makes a clicking or rubbing sound when running regardless if the compressor is running or not (even with fan on only). When the unit is shut off, the noise slows as the fan spins down to a stop. I thought something like a small stick or leaf had found its way in under the shroud, but after removing the shroud, there was nothing. I noticed my shroud had some damage and likely needs replaced, so I made some repairs to it and put it back on. While it was off, I ran the unit for about 2 hours and had no noise at all. I also turned the motor by hand and neither fan was hitting anything. There was no wobble in the motor shaft while it was running. The shroud was very tight and difficult to place back on. I'm thinking the shroud is placing some kind of stress somewhere to create the noise/rub. Has anyone run into this issue before, or does anyone have any ideas. The compressor seems to cycle on and off fine, so I'm thinking I go ahead and get a new shroud. Thanks.
Greg & Mary
2005, 31 ft. Classic - 2008 Ford F250
WGreg is offline   Reply With Quote
Old 04-06-2016, 06:09 PM   #2
2005 31' Classic
OK, so I found the problem. The outside squirrel cage isn't tight enough on the motor shaft and slipped up against the sheet metal housing. It has apparently been moving around enough to be quiet at times to extremely noisy at others. In looking at it, I'm puzzled at how to access the set screw on the squirrel cage. I would expect it to be easier than it initially looks. Does anyone have experience in accessing the set screw for or removing the outer squirrel cage on a Penguin air conditioner? Any advice would be appreciated. Thanks.
Greg & Mary
Noisy Air Conditioner gtc6452 2011 - 2015 International 10 09-30-2011 03:02 PM
Noisy Air Conditioner Larry71 Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-13-2006 01:01 PM
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 10:43 AM
Fantastic fans very noisy - wore out? ipso_facto Roof Vents, Skylights & Fans 5 07-17-2003 06:47 AM
Aquajet noisy? Why no more 3-way refrigs? Kistler Water Heaters, Filters & Pumps 5 11-24-2002 08:23 AM
