Old 07-28-2010, 06:05 PM   #1
1976 Argosy 26
Blandon , Pennsylvania
Noisy A/C
I have a 1976 Argosy 24. It has the original Armstrong A/C unit installed. The unit puts out cold air, but it is very noisy (Vibration).
Is this normal? Any thoughts on how to correct if not?
lpgasguy is offline   Reply With Quote
Old 07-28-2010, 06:27 PM   #2
2008 16' Safari
Destrehan , Louisiana
This has been talked to death. Almost all RV AC units make a lot of noise. I'm listening to mine right now. Yes, it's normal for a high noise level and no one likes it. The only thing worse is sitting in a hot trailer.
dlb435 is offline   Reply With Quote
Old 07-28-2010, 06:29 PM   #3
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Ours even 'grovels' in the background when turned off. They are right above, just live with it and beat the heat.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 07-28-2010, 07:17 PM   #4
Kevin245's Avatar
Normal... I don't know but at least it's in tune with the buzz from the univolt.
Seriously ours cools well but it rumbles like a freight train.
Kevin
Eleanor Roosevelt
Old 10-15-2010, 10:16 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
I recently had a vibration problem fixed on the Dometic Penguin A/C on my 2010 traylah.
There was a copper refrigerant line rubbing against something. It was loud and buzzy.
Now that it's fixed, it's just loud.
Old 10-16-2010, 12:56 PM   #6
Newberry , Florida
I'm still running the original Dometic on my '73. Just had an A/C man look at it because it wasn't working. One capacitor later, a minimal $40 repair bill and it works great and will freeze you out of the tin can. And oh yes, when the compressor kicks on, it sounds like a freight train driving through. I asked the A/C man if anything could be done to quiet that down. The reply was "no".
Overlander is offline   Reply With Quote
Noisy Refrigerator mok Refrigerators 3 09-06-2009 08:19 AM
NT 30 Motor/Fan Noisy Lumatic Furnaces, Heaters, Fireplaces & Air Conditioning 5 12-02-2008 06:31 PM
Fridge fan very noisy Roselie Refrigerators 5 03-13-2008 06:26 PM
noisy radio BINDER Electrical - Systems, Generators, Batteries & Solar 18 11-15-2006 09:19 AM
Noisy fan wacnstac Roof Vents, Skylights & Fans 6 04-19-2006 05:47 PM
