Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 10-09-2009, 09:34 PM   #1
Profile:  2007 19' Safari
Grapevine , Texas
No hot water in the shower !
Help ! 07 Bambi. I have hot water at both sinks but not in shower. Manual does not help. Any ideas on where to check?
LisaP is offline   Reply With Quote
Old 10-09-2009, 09:50 PM   #2
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
It may be that the shower hot water has a LIMITER on it to keep anyone from getting burned as the hot water is just that very hot.
You should be able to take the valve apart and adjust it to a higher temperature. Most domestic shower valves adjust up or down 3 degrees per notch.
If you had hot water before it may just be that dirt is in the valve and reducing the hot water flow. Again open the valve and check.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 10-09-2009, 09:57 PM   #3
2airishuman's Avatar
Profile:
hi lisa'
typically this is related to the fixture in the shower...
the mixer valve for hot/cold may be clogged or need tweaking.
IF it's a moen they have details on doing this on their website.
here are 3 of the threads on this issue with links to help, there are others.
How Hot Should My Shower Be ?
2003 Safari SS Hotwater heater not so hot
no hot water in shower
other LESS common issues can cause this, but start with the common stuff.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 10-10-2009, 07:58 AM   #4
Mikethefixit's Avatar
Profile:  1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
See you ask for 2air and U received.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336
My your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
No Hot water in Shower...ugh. Brow324 Sinks, Showers & Toilets 14 11-20-2009 11:31 AM
No hot water in shower - 2004 Safair a.moore Sinks, Showers & Toilets 4 11-05-2009 06:56 PM
no hot water in shower Susand Sinks, Showers & Toilets 4 04-18-2008 03:27 PM
No shower hot water Resorts Plumbing - Systems & Fixtures 3 07-11-2007 09:16 AM
Only hot water coming out of shower. TBKP's Overlander Plumbing - Systems & Fixtures 6 06-21-2003 03:41 PM
