Old 01-15-2016, 09:28 PM   #1
1967 26' Overlander
Anywhere , USA
No furnace, vent, or ducting...Whoops
Last night I added a new item to my list "Things we missed when we bought our Airstream." I was reading about winter camping and realized that we don't have a furnace. No vents. No ducts. A previous owner must've completely removed them.
When we bought it, we thought the only heating system was our ceiling A/C-Heater. Naivety. After a month of use, the heater spewed flames and that ended that. (I posted about thst previosly). Now, we use a little electric heater that we love. However, we want to dry camp and a furnace sure would be great. A thermostat would really be something too.
Thoughts? (Besides "How did you miss THAT?") Ideas?
Warmly, Beth
"wherever we go, we're always home"
Diogenes is offline   Reply With Quote
Old 01-15-2016, 09:42 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Name:	ImageUploadedByAirstream Forums1452919258.700476.jpg
ID:	255757i use this wall furnace. Might be an alternative to installing everything from scratch.
I run it through my inverter when not on shore power.
Brevi tempore!
Old 01-16-2016, 05:34 AM   #3
Gainesville , Florida
It may have had a catalytic heater in it. Some of thst era did.
Old 01-16-2016, 06:20 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Without ducting, and for dry camping, a catalytic heater would be worth a look.
They don't require a source of power, are quiet, and efficient.
Old 01-16-2016, 11:23 AM   #5
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
san francisco , California
Originally Posted by J. Morgan View Post
Attachment 255757i use this wall furnace. Might be an alternative to installing everything from scratch.
Brevi tempore!
That one doesn't require electricity does it?
I thought it was propane powered.
twolanehwy is offline   Reply With Quote
Old 01-16-2016, 11:26 AM   #6
belen , New Mexico
ARE you sure? there should be a place under the sink on the drivers side for a heater and if they took it out there'd be a patch on the outer wall? the flue vent is just ahead of the wheel well well again on the drivers side and thered be a capped off gas line under there also.
alantbird is offline   Reply With Quote
Old 01-16-2016, 11:29 AM   #7
1972 27' Overlander
Denver , North Carolina
I have a furnace and a catalytic. Love em both
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 01-16-2016, 11:47 AM   #8
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
Same here, enjoyed using catalytic (Wave6) for many years so far. Furnace is good but really noisy. Catalytic is silent and cozy.
Name:	ImageUploadedByAirstream Forums1452970046.390701.jpg
Dreamstreamr
2005 International CCD 25SS
Http://Dreamstreamr.com
Living the Dream
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 01-16-2016, 05:18 PM   #9
1973 31' Sovereign
Middletown , California
I use my furnace just warm up the trailer fast and then rely on electric portable heaters for the quietness factor. Also for boon docking a standard RV furnace sucks down batteries. I would get something that doesn't need electricity to run if I was in your position. I tried a catalytic heater, it worked great but wasn't vented and I thought it put way too much moisture in the trailer. I'd advise going with a wall heater or some other type of vented propane heater that doesn't run down your battery. It will be worth some trouble to fit something in that won't kill the battery. Boating catalogs have some great heaters and fireplaces if you don't find a home style heater that you can fit in. I've always wanted a furnace that was quiet and charged my battery, they have them now but they are very expensive and not small so I'm still dreaming. Airstreams from the mid 50's to early 60's had nifty heaters by the door that were like a round pipe with a reflector behind and a grill around the front and they vented straight up out the roof. I wish they were still made because they looked like that design worked well. You should be able to find a heater that is quiet and won't kill your battery but it will probably take some work to fit it in. Good luck! Leland
ijustlee is offline   Reply With Quote
Old 01-16-2016, 05:35 PM   #10
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Mr. J. Morgan,
Really liked the heater in your picture -
Is it gas with outside vent, electric, or what?
Who made it?, etc.
Also, loved your interior treatment of you Airstream - beautiful job!
Silver Hawk is offline   Reply With Quote
Old 01-16-2016, 05:46 PM   #11
1967 26' Overlander
Anywhere , USA
There is no evidence of ducting inside the trailer. Outside, I found a patch on the outer wall. Bo evidence of a vent. There is something on the front of the trailer...don't know what it was for originally. I included the picture. (It is sideways).
Warmly, Beth
Old 01-16-2016, 05:46 PM   #12
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
My original furnace had a hole in the heat exchanger. After a lot of thinking and reading here on the forums about heat options, I decided to go with small electric heaters. I do have a small catalytic for emergency use but when we camp in the cold a small electric space heater does a good job keeping us warm. 95% of the time one heater does the job in my Trade Wind but if it gets into the 20's we have a small one for the bathroom. By removing the old furnace it freed up lots of cabinet space under the counter too.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 01-16-2016, 05:48 PM   #13
2005 22' International CCD
Buckhorn , Ontario
Images: 59
Send a message via Skype™ to GT1963
Have you considered the Buddy Heater series??
If you will only use it here and there for the odd winter camping you might not want to get into a huge expense for a fully built in vented furnace which all run on propane with electric fan anyway.
I have used my little Buddy in my smaller trailer - 22', They work great. They all come with a self oxygen sensor so no worries about um dying in there.
A few years back when I had owned a 26' 61 Overland - that had the original furnace which looked cool but did not want to mess about with getting it working. I had looked at the larger Buddy heater, which you can attach a proper propane adapter connection. So was going to run a new line and up into the base of the old furnace. And just connect all legal and safely the buddy heater - with the conduit type propane line.
The portable heaters are great because you can pull them and use them in your home or garage and such. They are nice and quiet and heat up pretty good and fast.
Buddy Series - Heaters - Product
Everything will be alright in the end. If it is not alright now, then it is not the end.
GT1963 is offline   Reply With Quote
Old 01-16-2016, 07:23 PM   #14
1967 26' Overlander
Spartanburg , South Carolina
On my '67 Overlander, the item in your pic is the fill pipe for fresh water. It is atop the water tank, the cap screws off and you can fill the tank with a potable water hose. There should be a strainer under the cap to catch any debris that might fall in while doing that. I advise you make sure someone didn't remove or puncture the water tank at some point before running water into it. The water pump should be in the roadside front corner on the floor beside the tank. In mine you access the pump by removing the sofa cushions and lifting a small ply-wood hatch. The valve for draining the tank is also in that small compartment.
Jacob D is offline   Reply With Quote
Furnace Vent - How Hot? And Ducting? trekerboy LP Gas, Piping, Tanks & Regulators 1 05-28-2015 11:57 AM
Furnace ducting question? Mrcrowley Winter Living 6 08-26-2011 07:51 PM
Whoops! Thor Industries major 'miss' earnings.. mdrive Airstream "In the News" 4 12-03-2010 09:27 AM
Whoops- Broke Lighter Hole Cover willski33 Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-22-2010 08:52 PM
Whoops jumped the gun.. ;) Mrcrowley Member Introductions 4 05-14-2009 02:26 AM
