Old 04-18-2011, 03:04 PM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
No Drain Tube
I have my 65 Amb.ready to put back together.There is no sign of any kind of drain tube inside coming from the air unit.Have never tested the unit,so not sure if it works.
It is an older Coleman Mach.I will eventually replace for a low profile something when it quits.Do I need to put a tube in the wall and what size?
bwaysteve is offline   Reply With Quote
Old 04-18-2011, 03:13 PM   #2
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Not sure, but to keep thread alive...
Many versions included drain tube running from mounting "Pan" around A/C unit down between double walls of trailer, and dumping out around wheel wells... I can confirm that was design for 1980's and newer models...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 04-18-2011, 03:47 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Yes...inside the wall now while your at that point. I think its 1/2 inch hose (clear tubing from HD is perfect). Check the pan drain fitting size.
Old 04-18-2011, 03:59 PM   #4
drain hose
An AC drain line was installed in every model Airstream built, starting with the 1969 models, as standard equipment.
Fresh water drain AirEPotter 2011 - 2015 International 11 05-04-2011 02:34 PM
Continuous drain from fresh water casa3805 Fresh Water Systems 15 03-14-2011 06:54 AM
Fresh Water Tank Drain Jack46 2009-2015 Flying Cloud 3 03-06-2011 01:37 PM
Aft relief tube dripping through floor below sink kaiaua 1974 - 1979 Sovereign 5 02-21-2011 10:21 AM
Where do the roof A/Cs drain on 345 moeriv Classic Motorhomes 4 01-19-2011 08:20 AM
