Old 06-05-2010, 03:12 PM   #1
2009 30' Classic
Chesapeake , Virginia
newbie question on use of air conditioning
All,
Haven't used my AC yet but was wondering, do I keep the vents open while the AC is on to prevent condensation or seal her up tight and let her run? Also, I'll be living in our 30' classic for 3 years during the week and was wondering if I should leave it on all day or fire the AC up when I get home after work? I don't want to burn up the AC prematurely.
goutes is offline   Reply With Quote
Old 06-05-2010, 03:18 PM   #2
2010 31' Classic
Mobile , Alabama
Send a message via AIM to Greg N Send a message via Yahoo to Greg N
Use it jus like you would the one in your house...
Greg
Greg N is offline   Reply With Quote
Old 06-05-2010, 03:56 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Originally Posted by goutes View Post
All,
The answer to your question is yes.
I live in my Excella and, depending on the weather, I do every option you listed. I only leave the roof vents cracked a little when running the AC. With the windows shut, only the hottest air gets to them anyway and, as far as I am concerned, it's welcome to exit the vents.
Right now, the daytime temps are in the mid 80s to low 90s most of the time. When I go to work I leave the Fantastic Vent in the bedroom blowing out on high and crack a window in front. When I get home from work, I shut off the FF, close the window, and turn on the AC. Not necessarily in that order. It gets comfortable pretty quickly. When it gets warmer, I leave the AC running full-time.
As far as condensation goes, running the AC tends to dehumidify the air making that pretty much of a nonissue. Lately I have been noticing condensation on the windows in the morning, but it's on the outside.
You'll figure out what works for you pretty quickly. Enjoy!
Vaughan
Old 06-05-2010, 04:08 PM   #4
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Vaughan speaks from experience, as a full timer while we only go out occasionally.
If you haven't used it yet and it is June, you must be in the shade or getting an ocean breeze. We have had the house A/C on for a month and if we were in the camper it would have been on sooner. I would use the Fantastic fan as it has a sensor that can close it with rain and also operate the fan thermostaticly.
Old 06-05-2010, 04:21 PM   #5
1983 34' Excella
1967 24' Tradewind
Images: 32
Dave is right about the rain sensor. I couldn't do this without it. In fact, it kept the bed dry just yesterday. When I can afford it, another is going in the front vent. Wouldn't consider one without the rain sensor.
Vaughan
Old 06-06-2010, 05:39 AM   #6
2009 30' Classic
Thank you everyone for your input. I have 2 of the FF with rain sensor so I'll leave those on during the day and turn on the AC when I get home
Old 06-06-2010, 11:04 AM   #7
1983 34' Excella
1967 24' Tradewind
Images: 32
The people I know with two FFs recommend using one blowing in and the other blowing out. You might want to try it both ways.
I also have one of their Endless Breeze stand alone 12v fans. It is a nice extra fan. I am using it to blow into the freezer during a defrost right now.
Vaughan
Old 06-06-2010, 01:56 PM   #8
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Recent Airstreams have Fantastic Fans that only blow outward. I called FF and got a kit to make the front fan blow in or out. It is an easy install. FF didn't even charge me for the kit.
You can actually just switch the fan motor wires on the front fan to make it blow in.
When we leave the cats in the trailer with the AC on, we open both vent covers and set the thermostats just below where the fans will run. If the input voltage fails, the fans will kick on and save the cats.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Air Conditioning and batteries StevenG Boondocking 18 08-29-2011 11:45 PM
Air Conditioning Question floridalarry Member Introductions 8 05-29-2011 12:10 PM
Air Conditioning help Chipster Furnaces, Heaters, Fireplaces & Air Conditioning 17 08-29-2007 07:16 AM
Air conditioning wiring chuman70 Furnaces, Heaters, Fireplaces & Air Conditioning 14 06-02-2007 07:33 AM
Air Conditioning Help Please!!! 85MH325 Furnaces, Heaters, Fireplaces & Air Conditioning 26 08-16-2003 08:58 AM
