Old 07-25-2005, 11:18 AM   #1
New owners.
I have a 2004 Bambi & being in Ca. have not used the furnace yet.I decided to open up the little door & see if it needed a dusting.Inside tucked away and attached with a zip tie was the lighting instructions.Well I am not sure if this could have been a fire issue so I removed it.Funny thing is on the front cover it states it must be attached at all times,I guess it is like a new pillow with the tag that states it's not suppose to be removed either.
cynthia is offline   Reply With Quote
Old 07-25-2005, 01:06 PM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
If I'm not wrong that tag was in an area that you can access by opening the outdoor panel. That tag is tied to the side of the furnace that stays cool and is separated from the exhaust. Not really a fire issue.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 07-25-2005, 01:32 PM   #3
LeeMo's Avatar
Acworth , Georgia
Post Vital Documents
Cynthia:
Being the owner of an older model Airstream, every piece of documentation that I could find with my unit was of value to me. So, save your paperwork for the folks who might own your vintage unit 25 or more years from now. They will certainly appreciate it.
Congratulations on your new Airstream and Happy Camping!
LeeMo
1979 24' Excella Motorhome
LeeMo is offline   Reply With Quote
Old 07-25-2005, 02:39 PM   #4
When I was going through our 2005 Bambi, I noticed the same thing. I found it a little odd that the outer portion of the door had a warning about being too close to flammable material, while there was a paper manual zip-tied inside. I removed the manual and added it to all the other paperwork and manuals (ie. in the big binder we keep on the top shelf of the wardrobe).
Claybuster is offline   Reply With Quote
Old 07-25-2005, 02:59 PM   #5
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
My newly installed heater is the same way. I think if you examine the little instructions, it's a special fireproof paper, and it's in an area that doesn't get that hot anyway. I left mine on.
Stephanie
Owner's manual Cheryl 1978 Excella 11 08-04-2012 09:35 AM
Safari owners Jerry Sulkin 1969 - 1973 Safari 30 02-20-2006 07:07 PM
PROUD NEW OWNERS of a 1974 International Overlander Anna Our Community 6 11-09-2002 07:29 PM
'67 Tradewind owners manual BentEar 1959-69 Tradewind 1 07-21-2002 05:15 PM
Argosy Motorhome Owners Manual & Brochures WANTED Rik Airstream Motorhome Forums 5 03-02-2002 11:21 PM
