Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 01-06-2009, 02:36 PM   #1
fotochop
fotochop's Avatar
Profile:  1969 23' Safari
New Orleans , Louisiana
New NT-30SP fires 10 sec. then goes out, fan on
Installed a new Suburban NT-30SP in my '69 Safari and I'm testing it with the front cover off. Fan comes on, flame comes on but only for 10 seconds or so before going out, fan runs continuously and won't switch off. Since I'm "jumping" the trailer's thermostat (see below) seems like the unit should be ON (with flame) as long as the 2 thermostat wires are connected.
(Unit arrived with only one blue thermostat wire showing. Schematic showed second (blue) thermostat wire connected to red 12V wire. I added this second thermostat wire myself, then jumped the thermostat by connecting the two blue wires together. Correct me if I'm wrong here, but I think I'm ok with that. Sort of a 'bench test' but unit's still in the trailer.)
Any help appreciated.
Rick Olivier
Rick Olivier
New Orleans
http://www.rickolivier.com
fotochop is offline   Reply With Quote
Old 01-06-2009, 06:02 PM   #2
bryanl
Profile:  1975 29' Ambassador
Reno , Nevada
sounds like the overheat switch, maybe.
fan on says thermostat calling for heat. that's OK. typical of old style controller boards to leave fan on as long as thermostat is calling for heat, no matter the burner status.
furnace wouldn't fire if sail switch wasn't working
but 10 sec before flame-off is rather short for most overheat switch problems. That safety usually gets worked when duct air flow is too low to remove furnace heat. Poor duct flow seems to be almost a norm in a lot of trailers.
Old 01-06-2009, 06:57 PM   #3
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Rick Olivier
You cannot properly test the furnace with the front cover off.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-06-2009, 07:04 PM   #4
fotochop
fotochop's Avatar
Thanks, Andy, I had a feeling that might be causing problems. I'll try it again with the cover on and see what happens. I was fortunate to find a Suburban manual here:
Service Documents
the same place I found my (old) Dometic refer manual, and it contains a lot of valuable information..in case others may be searching for manuals/troubleshooting, etc..
Rick Olivier
New Orleans
Dometic Refrigerator Fires? Cracker Refrigerators 89 07-27-2008 04:59 PM
NT-30MA to NT-30SP furnace change '79 Excella 500 SafeHarbor 1978- 1979 Excella 500 17 08-22-2007 08:36 AM
Florida Fires Devoman Off Topic Forum 8 05-16-2007 06:16 AM
Water pump cycling every 1-2 sec?? BOBHASTINGS Water Heaters, Filters & Pumps 19 09-06-2006 04:22 PM
College Football Fans (SEC) rebel beck Off Topic Forum 0 06-20-2006 03:57 PM
Forums Directory
