Old 02-02-2013, 09:22 AM   #1
rogerdodger's Avatar
Fresno/Clovis , California
New Heater-What duct and where do I get it?
I am installing a new heater in the same place as the original. However, a PO tossed all the ducting. I need to run a 4" duct to the bedroom. Can I use the stuff from HD or Lowes, and the small registers? I cant seem to find any online anywhere.
Thank you,
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 02-02-2013, 09:30 AM   #2
1974 Argosy 20
Kooskia , Idaho
You can use the metal dryer duct that HD or Lowe's has with fair success. It is not much different from what was in your Argosy to begin with. But, if you can find a way to use the straight solid metal ducts and fittings (el's etc) you will have better air flow, especially on longer runs.
Most RV parts places have some round plastic air outlets for a few dollars which may be easier to install in some locations than the home stile rectangular ones. They also may have duct material.
Old 02-02-2013, 10:37 AM   #3
dznf0g's Avatar
Oswego , Illinois
I used this place.
Flexible Ducting / Uninsulated Flex - DW Inc.
-Rich-
Old 02-02-2013, 02:52 PM   #4
I did locate small round heater registers in brown and white locally.
Thanks again,
Roger
Air# 29488
Old 02-20-2013, 11:05 AM   #5
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
A tip on replacing the heater, if your airflow is too low, the output exhaust gets
really hot, my test is, can I hold my hand in front of it for 5 seconds.
I replaced the furnace in mine and needed to ad a duct in the bedroom to get the temp down. The old RT35 had a jet engine for a fan, new RT30 does not.
Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
Jim in Pima is offline   Reply With Quote
