I checked the drain, it is clear. I found the phone jack going to the comfort module had some water in it. I assume this came in during the storm. I removed the water and cleaned it up.
The ac still doesn't work but the heat pump and fan by itself do. I checked the control board, it has
12v and 120v. I also checked the cable from the comfort module, but cannot find which pin is the ac signal. They read left to right from top unit 12v/ 0v / .4v /
12v. When the ac is switched on (on the comfort control module)
I believe something in the control board is broken because of the water. I will probably order a new board as it is cheaper than going to the dealer.
Thanks for the help
