Old 07-15-2013, 05:56 AM   #15
richinny's Avatar
2011 34' Classic
i'm glad it worked out :-)
Ricky
Old 07-15-2013, 06:32 AM   #16
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by Foiled Again View Post
" . . I didn't note before that I might have tried to overcool - 70 degrees with outside temp over 95 and rain on and off for days. Humidity was 99% and the drain wasn't dripping but running solidly. When I restarted it I left it at 75 degrees and put the fan on high.
I regularly turn it up to 80 when I'm out. I want to keep it bearable, but don't need to come into an icebox . . . "
Why I run a big dehumidifer constantly. A target of interior 35-45% humidity and temp of 73F in the evenings. Daytime interior temps may reach 77-79F before shade covers the TT in late afternoon. Outside, 90+% humidity and temps of 95F. The dehumidifier runs the electric bill higher, but dry cool air is more easily obtained.
Old 07-15-2013, 07:49 AM   #17
Colonial Airstream NJ
Colonial Airstream's Avatar
1968 17' Caravel
Lakewood , New Jersey
Images: 79
Thank you for helping out another fellow Airstreamer and our customer when we were closed.
Patrick Botticelli - Colonial Airstream 1121 Route 88 Lakewood, NJ 08701 - 1-800-265-9019 www.colonialairstream.com
Colonial Airstream is offline   Reply With Quote
Old 07-15-2013, 02:00 PM   #18
2008 27' Safari FB SE
Pfafftown , North Carolina
Saturday Hours ?
Is Colonial now closed on Saturdays?
sunnygirl is offline   Reply With Quote
Old 07-16-2013, 07:02 AM   #19
1968 17' Caravel
Images: 79
We are open Saturdays 9am to 6pm est.
Old 07-16-2013, 08:33 PM   #20
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Problem happened again. Now I guess we start the darned warranty process. CRAP.
I did call Colonial and get a suggestion to turn the battery switch to standby as well turning off the circuit breaker. The service department said that Dometic had a fire in it's Texas plant a while back, and quality control has been poor every since. Apparently the closest AUTHORIZED Dometic facility is in Ashland VA - over 100 miles from here. Pain in neck.
I did pull the cover off the thermostat and unplug/replug the phone cable connection to the ceiling unit. Accomplished zero.
Eventually when the fan runs long enough (and the outside temp gets low enough) the thing somehow resets itself and report the inside temp. accurately. Then the air conditioner will run - for a while. I'm about ready to pull the inside cover off the A/C and look for the phone connection in the ceiling unit. If there IS any sign of moisture I'll let you know, but I'm leaning to the inside sensor being defective.
Crap, crap, crap. HOT CRAP Paula
Foiled Again is online now   Reply With Quote
Old 07-16-2013, 09:06 PM   #21
richinny's Avatar
2011 34' Classic
paula, after drying mine out i wrapped a sandwich bag around the connector and closed the ends with twist ties. i think i even put a piece of paper towel in the bag. the wire sweats and runs down into the connector.
Ricky
Old 07-18-2013, 11:16 AM   #22
Update
I ran the unit with no trouble for the past two days - with the inside cover (air distribution unit) off. This would have limited the amount of condensation that could build up in the unit on the inside. I've always been meticulous about turning on exhaust fans when I'm cooking or showering to keep the buildup low.
This morning I got up on my little step stool after turning off power at the circuit breaker and battery (for the low voltage stuff). I unplugged the phone cable in the overhead unit, slipped a piece of shrink wrap over it, shrunk it and sealed it and turned the unit back on. If it's running tonight I'll put the inside panel back up.
Should be a solid fix now. PLEASE !!!!!!
Hot mama Paula.
Old 07-18-2013, 04:33 PM   #23
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Hot mama Paula.
Try some Gremlin Grease on the contacts...
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-18-2013, 04:47 PM   #24
Fly at Night's Avatar
2010 27' FB Flying Cloud
Fraser Valley , British Columbia
Jeeze Paula, I sure admire your trouble-shooting/mechanical ability. Ditto to all those who replied.
I don't understand a lot of it, but I had to muck-around with my a/c a bit during my last trip. Temp outside was 100.4., but the humidity was low (I think). I found if I kept a/c at 73, it was bearable/fairly comfortable inside.
Hope you do not have any more problems.
Fly at Night is offline   Reply With Quote
Old 07-18-2013, 05:31 PM   #25
My mantra against the "girls aren't mechanically inclined" is - a sewing machine IS a power tool, a stand mixer IS a power tool. The sewing machine thing can be proven because more than a few men on this very forum have done their own upholstery and even dare I say it, curtains! However I DO still think that a high heel can be a decent hammer in an emergency and a kitchen knife will insert a screw safely.
Paula
Old 07-18-2013, 08:50 PM   #26
lewster's Avatar
Naples, FL , Hood River, OR
Paula
Hope those screwdrivers (....er....kitchen knives) are not made by Henckel, Wusthoff or Kyocera!
Old 07-18-2013, 09:12 PM   #27
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
Control Sensor up in the unit. blows out cold air a few minutes then goes into hot air fan mode.. Had it happen to me last year. $267 and "HOT DIGGITY" it worked !
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
