Old 07-30-2002, 09:37 PM   #1
Vagabond
TheBigRedTruck's Avatar
1973 31' Sovereign
Fort Meade Md. RV park slot 8!! , Motorsports Photographer
Images: 36
Send a message via AIM to TheBigRedTruck
Question New Colman A/C (HELP!!!!!!!)
My old Coleman is FUBAR!!!!!!!! So i have looked at new a/c's but am told you can only get a drip pan for the Penguin!!!!!! But is a new Coleman so diff. from a old one?????????? Can you make the old Coleman drip pan work with a new unit?????? If so how??????I just dont have the $$$ for a new A/C and a drip pan, i can get a good deal on a used Coleman....... Why dont we find some one how has reconditioned units that would give us a deal!!!!!!!!!!!!!! Thank for your time!!!!!! DaPlumber
TheBigRedTruck is offline   Reply With Quote
Old 07-30-2002, 09:48 PM   #2
83Excella's Avatar
1983 27' Excella
Airstreamville , Kansas
coleman a/c drip pan
Look in the Dealer/Vendor forum for salvage yards. Also try a web search.
John
83Excella is offline   Reply With Quote
Old 07-31-2002, 09:23 AM   #3
Most dealers will not get involved with second hand parts. Our judicial system, however unfairly, dictates a greater liability for selling used parts than it does for new parts.
It is far too costly to defend one's self on used parts. Scratches, dents, discoloration, tears or other imperfections, ALL, carry that liabilty. The only way around it is to get the buyer to sign a "hold harmless" agreement. But how can you get the buyer to do that when they can't see the item?
Bottom line, is that many good used parts are destroyed.
inlandrv.com
airstreamparts.com
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-31-2002, 01:00 PM   #4
Vagabond
1973 31' Sovereign
Images: 36
Can you make the old Coleman drip pan, work with a new Coleman unit?????? If so how??????
Old 07-31-2002, 06:18 PM   #5
You can reshape them with some heat and a little patience.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-31-2002, 09:19 PM   #6
Vagabond
1973 31' Sovereign
Images: 36
Thanks Andy!!!!!!If you can reshape them with some heat and a little patience. I dont have much patience but i got a hell of a lot of time, on my hands!!!!!! If i cant do it no one can!!!!!!!
Old 08-05-2002, 03:31 PM   #7
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Coleman AC Switch
Do you still have the Fubar'ed AC? I am looking for the control switch that has nine positions. My AC is a Coleman Supermach.
It appears that my switch has been replaced with a 4 position switch and does not match up to the faceplate which indicates that there are nine positions including the off position.
My AS is a 71 Overlander 27 feet
Ken
smily is offline   Reply With Quote
Old 08-05-2002, 05:39 PM   #8
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
I will ask another A/C question. My fan on my Coleman puts out so much air it makes a geat deal of noise in the trailer. Anyone know of a way to lower the noise level.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 08-23-2002, 10:41 PM   #9
Vagabond
1973 31' Sovereign
Images: 36
Jim, dont you have a 3 speed fan??????? Smily, need more info???? I will go out and look at the old one this weekend for you!!!!!!
Never has so few. Done so much, With so little, That now we can do anything, With absolutly NOTHING!!!! AIR# 300
Old 08-24-2002, 07:59 AM   #10
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Jim,
I assume your Coleman came equipped with a one speed switch. Keep in mind that it was designed for a minimum amount of air flow. You may find that you could freeze up the coils if the airflow drops below the minimum to keep enough warm air passing to keep the moisture in a liquid state as it collects on the coils.
I remember a problem I had with my old trailer with a new Duo-Therm Brisk air unit. It had a three speed fan and during my first trip the Destin Fla, the coils froze up. It ended up being a problem with the control board. The service guy who took care of me said that they do experience a lot of complaints about freeze ups in their area. In high humidty climates when the fans are dialed down to low you can freeze up even though these units are designed to run at lower speeds.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 08-24-2002, 11:34 AM   #11
Jim Clark's Avatar
No it is a 2 speed. I have Hi Fan Lo Fan Hi Cool and Lo Cool. It is starting to stick also. I will at the least get up and lube it as much as I can. I see fan replacement in my future.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 08-24-2002, 10:14 PM   #12
Vagabond
1973 31' Sovereign
Images: 36
Jim do you whant my old fan??????? I will give it to you if want it!!!!!! Just pay shipping..........
Is A/C original? whistler Furnaces, Heaters, Fireplaces & Air Conditioning 2 01-19-2004 04:32 AM
34' Excella 1000 needs cooler A/C cjholloway Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-17-2003 06:50 PM
understanding A/C options Lexxy Furnaces, Heaters, Fireplaces & Air Conditioning 24 08-02-2003 05:29 PM
A/C blowing the breaker Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 13 07-08-2003 10:52 AM
Retrofitting Roof A/C 59toaster Furnaces, Heaters, Fireplaces & Air Conditioning 4 03-14-2003 04:54 PM
