Old 06-10-2011, 05:09 PM   #1
MINERVA , Ohio
new atwood 7900-11 furnace help
hi, just installed all new gas lines, regulator,stove,gas-electric refridgerator,water heater and a atwood 7900-11 furnace. Problem is when I turn the thermostat up the blower comes on it trys to light 3 times and then goes to fault, (3 light flash) maybe it will fire up 1 out of 10 times, I pulled the ignighter out the gap looks good and the spark does too, when I ran wires to the thermostat I went with the white wire out of the furnace and a positive, is this the correct way? I cant figure out why it will not fire up each time I call for heat. All my other new appliances work great. thanks for any advice.
hgut is offline   Reply With Quote
Need advice on furnace. SilverRanger Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-28-2011 03:47 PM
Suburban furnace replacement for '66 Trade Wind Ben in MT Furnaces, Heaters, Fireplaces & Air Conditioning 0 05-17-2011 08:12 PM
Stove & furnace for Bambi II Becky B. General Appliance Topics 4 03-26-2011 08:23 PM
Removing International Furnace from 1965 Safari miscwires Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-17-2011 05:10 AM
Furnace Noise azflycaster Furnaces, Heaters, Fireplaces & Air Conditioning 12 03-06-2011 11:36 AM
