02-13-2012, 07:36 PM
#21
2008 27' Classic FB
Burkburnett
Originally Posted by Chuck
Curious about this: I noticed that in the Dometic sales info that the heat pump shuts off at 40f, and switches over to your furnace. What if you don't have a furnace, and its colder than 40? does it just "not work"? ...
It looks like no one else has taken a stab at this. I think we all understand that heat pumps become less efficient as the outside temperature drops. The control board utilizes a thermal sensor topside to decide when to switch over to furnace mode. At that point the control board provides a DC voltage to the furnace just as if the old style thermostat had called for heat. It would seem possible to install a dedicated 110v outlet operated by an appropriate relay. The control board would think there was a standard furnace attached but it would really be switching on an outlet the electric heater was plugged into. This is probably not supported by Dometic, but it seems to be do-able. A downside is that without the ducted heat, none would be distributed to the plumbing. Any other thoughts on Chuck's question?
AIR 47751
02-13-2012, 08:39 PM
#22
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
Goose, I think Lew pretty much covered it: rv heat pump isn't going to be a viable alternative to a furnace, even if it did have a heat-strip. I'm not much concerned with the nifty switch-over feature, itself. (fwiw, there was never any ducted heat to the waste tank on my particular trailer, anyway, as it didn't come from the factory with any tanks below the floor; the black tank sits "on" the floor, so its part of the interior of the trailer. Of course, I'm planning on changing all that. even so, its not something I think is really worth the trouble to concoct, unless you're planning on going out in very low temps, (way below 32F), and staying there for some time. But I digress...).
John: your trailer was originally equipped with a condensate drain tube; I found mine a couple of years ago when I had the ceiling panel down; its was tucked up there out of the way, just forward of the a/c; runs down the street side wall just forward of the street side wheel well. There's nothing to hook it up to on the a/c, though. (also an after-market Coleman).
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
02-14-2012, 07:11 AM
#23
1973 25' Tradewind
Bloomsbury
, New Jersey
drain
Chuck,
If I get a new A/C with one of those pans, would I be able to use the pan with the drain tube? MPJ
02-14-2012, 02:35 PM
#24
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
That's the idea, anyway.
no direct experience with this, myself, but I can't think of a reason why you wouldn't be able to connect the drain tube.
Air:291
Wbcci: 3752
'73 Safari 23'
02-15-2012, 10:37 AM
#25
Vintage Kin
Fort Worth
A friend in the A/C business (and RV'er) recommended COLEMAN as being best built, overall, but to especially avoid ADVENT, the Chinese knock-off (I was looking for cheapest 15k A/C).
I, too, prefer the low-profile units.
02-17-2012, 09:24 AM
#26
1981 31' Excella II
New Market
, Alabama
I am on the fence about the Dometic. I am reading too many posts about Dometics not working correctly but most seem to be heat pumps. Maybe I should just pull my old Coleman and do a complete referb on it as opposed to getting a new one and having it die as soon as the warrantee runs out. I wonder if the new units are all aluminum tubing as opposed to the older copper systems. The compressor on my old Coleman works but the rest of the unit is pretty sad.
Perry
02-17-2012, 11:33 AM
#27
Vintage Kin
Fort Worth
You can also look at the more HD versions: marine, big truck, etc. Changes in materials, improved coatings, etc. Cost is a few hundred more.
02-17-2012, 11:41 AM
#28
2012 25' Flying Cloud
gresham
, Oregon
Originally Posted by marzboy
OK I have searched the threads and now I want to know...what would be the best a/c for me? I know nothing about the subject. After reading and asking questions I am still unsure. I am kinda leaning towards the Dometic and I like low profile. Any and all advice will be greatly appreciated!
Hi,
You might wish to contact the engineering dept. at the manuf.of your choice and inquire about the sound levels of low profile vs standard height. Generrally speaking,when you decrease the plenum,the resulting turbulence increases noise level inside conditioned space.
02-22-2012, 09:52 AM
#29
Tool Hoarder
West
Hello all thanks to all for chimeing in. I have decided to go Dometic Penguin. Not sure if I'm going with the Heat pump or not yet. It either uses a single zone tstat or the CCC (comfort control center). Dometic is really vague about their products. Either way I like the low profile of the Penguin and they both have the same dimensions regarding the roof opening. My plan is to:
1) Remove A/C (done)
2) Clean and prep (done
3)Patch the roof and make the existing opening smaller (done)
4) Fix broken rivets in the roof stringers (done)
5) bend some additional support stringers out of some scrap 5052 .032
6) make a brace for the opening out of some scrap MGP
7) Hopefully get the unit in a couple weeks and lure my friend Paul back with some Beer and Dans Subs.
I am not going to buck the rivets in the patch til I get the unit for some last minute adjustments.
Will post more, stay tuned!
03-13-2012, 08:26 AM
#30
Tool Hoarder
West
Ok people I went with the Dometic Penguin II with no heat pump. Pretty straight forward install. Built a 14 1/4"X14 1/4" wood frame out of some Scrap MGP that I sealed with some left over West Systems Epoxy. I made a patch out of some left over 5052 from the belly pan. Drilled, sealed and riveted to the roof, then installed the new a/c. Pretty easy which scares me a little....
03-13-2012, 12:43 PM
#31
1950 Flying Cloud 7039
1950 21' Flying Cloud
Allen
What about the inside? Do you have pictures of the drain pan?
03-13-2012, 10:36 PM
#32
Tool Hoarder
West
I havent taken any pics of the inside yet. There is no drain pan. I will be hooking up a drain wnder the skin thru the floor. Iwill post more pics when I do the drain.
03-14-2012, 11:40 AM
#33
Allen
How much does the AC weigh and did you just muscle it up there while standing on your scaffold?
I am confused about the drain pan. There are a couple mentions of differnet pans/cups. What is needed and not needed? Do the pans aleviate the need for a drain hose? I do not have a drian in my trailer wall and would have to do major interior removals to add one.
Thanks for letting me drill you for answers, but I am right behind you on installing an AC and am glad for the advise.
Gene
03-14-2012, 02:05 PM
#34
1981 31' Excella II
New Market
, Alabama
The low profile that he purchased has to use the Airstream supplied drain pan. The Briskair I believe will use a kit supplied by Dometic for Airstreams.
Perry
03-17-2012, 08:11 AM
#35
Tool Hoarder
West
I might be mistaken but I was advised to fore go the pan and do a drain tube down the interior wall of my trailer. I hope that was correct because I don't want to get up there and do that again!
The weight of the unit is a fraction of the old monstrosity ( net weight 110lbs). It was pretty easy for my friend and I to get it up on the scaffold an set it into place.
03-17-2012, 08:23 AM
#36
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
Don't forget to drill a hole or two in the wood framing for the electrical access and the drain line. It is also much easier to feed the drain line without the AC in position.
03-17-2012, 08:37 AM
#37
1981 31' Excella II
New Market
, Alabama
The drain tube should be there already. The pan catches the water and funnels it into the tube. I think the pan is your only option for catching condensate on the low profile Dometics. I thought we covered this already?
Perry
03-27-2012, 10:13 PM
#38
Tool Hoarder
West
Due to my inexperience in all things trailer and a little misunderstanding with a vendor, I had to remove the A/C unit to add a drip kit. Promptly followed with several shots of Tequila. Please file under rookie mistake.
03-28-2012, 05:09 AM
#39
1981 31' Excella II
New Market
, Alabama
That is the same kit that comes with my Briskair. So the same kit that works on the full size units also works on the low profile units.
Perry
03-28-2012, 08:00 AM
#40
Tool Hoarder
West
Perry
I had to drill a couple small holes but yes it fit.
