Old 05-22-2011, 05:47 AM   #1
The truth has no agenda
MJMarkhams70's Avatar
1970 27' Overlander
Katy , Texas
New ac woes.
Toward the end of last year, I installed a new 15k btu DuoTherm ac unit atop the 70. It worked great. Now that it's hot again I tried to crank up the ac and it's not working properly. The fan runs on low and med with no compressor. And on hi the compressor runs with no fan. I have 30 amp service in both location where the trailer is kept and it's the same on both.
Thoughts? Thanks.
WANTED- 1- 22x40 Curved Glass Window and 1- 22x18.5 Curved Glass Window
MJMarkhams70 is offline   Reply With Quote
Old 05-22-2011, 07:14 AM   #2
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
not sure, but it sounds like one or more of your capacitors is bad. I had that happen in a coleman once.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 05-22-2011, 07:56 AM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Along with checking the start and run capacitors, and the motor starter device (PTCR), I would look at your controls (I am assuming that you have a direct blow unit with manual controls). Your problem could be in either the selector switch or the thermostat control. You should find a Dometic factory authorized repair facility, as your unit should be under warranty if it is less than 2 years old.
Old 05-24-2011, 07:47 PM   #4
1970 27' Overlander
Katy , Texas
dropped the trailer off at an authorized repair shop for the AC today. they may be able to get things back up and running by the weekend. I hope so as having the AC cooling will make being in the trailer a great deal more pleasant while working...
Transmission woes 1987_345 Classic Motorhomes 7 07-21-2011 09:43 AM
F-150 torque converter lock-up woes... Dave Park Tow Vehicles 30 06-09-2011 08:27 AM
30# Alum. tank woes! Wingeezer LP Gas, Piping, Tanks & Regulators 13 05-26-2011 11:50 AM
