Old 12-15-2011, 09:08 AM   #15
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Originally Posted by perryg114 View Post
The wall thermostat was manditory or an option?
Perry
That was something that came along later than our trailers. Actually earlier, too, with the Armgstrongs. The ones in the 1980s just used the controls built into the lower units. I don't know when that started and/or ended, perhaps someone can chime in on that. There are lower units available that have the simple thermostat and controls built in for replacement of the kind that you have.
Of course, upgrading to the wall units is an option, but more work. I didn't go down that path.
Vaughan
Old 12-15-2011, 12:02 PM   #16
Missouri Valley , Iowa
Perry,
The wall mount unit was used because the original t-stat, also a digital, was tied to the furnace and it was wall mounted. I don't know if other options were available. This AC was installed on my '02 30' Classic w/slide.
Dan
Farmer Dan is offline   Reply With Quote
Need options for 3000 watt inverter Dwight Batteries, Univolts, Converters & Inverters 1 08-30-2011 08:55 AM
2012 Options judyjudy Buyer Guidelines 1 08-18-2011 12:21 PM
Converter connundrum: fuse panel options? Phrunes Batteries, Univolts, Converters & Inverters 0 08-17-2011 07:53 PM
Argosy without A/C - options? my3sonsdad Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-28-2011 02:40 PM
window operator replacement options GR8DANE Windows & Screens 17 01-10-2011 09:09 AM
