Old 07-10-2018, 06:18 PM   #1
ghaag's Avatar
2014 30' FB FC Bunk
2007 25' Safari FB SE
2014 Interstate Ext. Coach
Jonesboro , Arkansas
New AC/Heat Pump guidance
I am wanting to install a new 15,000 BTU AC/Heat Pump unit on my 2007 Airstream Safari, has anyone done this recently, if so what would you recommend?
Thanks in advance,
Greg
ghaag is offline   Reply With Quote
Old 07-12-2018, 11:23 AM   #2
ghaag's Avatar
2014 30' FB FC Bunk
For clarification here, what I am trying to figure our is should I go with 13,500 BTU or 15,000 BTU unit.
Thanks!
Old 07-12-2018, 12:20 PM   #3
2007 22' International CCD
If you are camping a lot in the hot and humid, or out in the scorching West like I do, 15K BTU will probably be better, IMHO.
What's on the rig now, and how well was it working for you were you have camped?
Rich, KE4GNK/AE, Overkill Engineering Dude
Old 07-12-2018, 01:55 PM   #4
ghaag's Avatar
2014 30' FB FC Bunk
Thanks for your feedback! 11,000 BTU is what came on the unit and there are times it is not adequate for our taste.
Old 07-12-2018, 02:22 PM   #5
Then a little more to think about. The 13,500 BTU is considerably more powerful than the old 11.000 BTU.
How badly was the 11,000 falling short? Running constantly and not getting cool enough? Or just not getting cool enough?
The issue now is if you go too big in the BTU capability, it will cool down way too fast, shut down, and will not have removed enough humidity for comfort in a humid area.
In a very hot low humidity area, humidity control does not matter much--you want brute force cooling in the SoCal desert where I live.
However, when you live in Alabama, like I did, an over-powered A/C will drop the temperature very rapidly, but it will feel cold and clammy instead of comfortably cool and relatively dry. The unit doesn't suck out the moisture enough.
I keep a temperature/humidity sensor in the rig when we are on the road, so I can detect humidity issues. It seems relative humidity is often more important to comfort than the temperature. Around here, humidity is running 35-40 percent lately, and that feels very steamy to us current desert dwellers... In Alabama, I could NOT get the house to that low a humidity even running two huge AC units almost constantly--it was just that oppressive outside in the summer. I had to do a lot of work to reduce air exchange (and humidity intake) on the house. Got it better, but not ideal.
I'd love for a few other folks with a similar size Airstream to yours to chime in and relate their environment to the size of the Air Conditioner BTU rating and their resulting comfort level. It might be that a 13,500 would be better for you than a 15,500 BTU unit--I'm just not sure how to accurately pick that one, given the humidity where you live...here in the desert, it's usually "go big, or go home"! When we travel back to visit family in Alabama, we typically go in the cooler weather--to the point we need heat at night to be comfortable...
Old 07-12-2018, 02:38 PM   #6
2016 30' Classic
Victoria , British Columbia
I would reconsider whether a heat pump model is required. A heat pump is a very complicated (compressor, fan, condenser, evaporator, reversing valve, etc.) method of making warm air, and discharging it into the area of an RV that already contains the warmest air in the unit. And to add to the absurdity, it only generates heat down to around 40F. A small fan driven ceramic heater at floor level will discharge its heat to the area with the coolest room temperature, and will do a much more efficient job of circulating air. I have AC/heat pump combos in both my Mobile Suite fifth wheel and my Airstream and always default to a good quality heater at floor level.
Camr is offline   Reply With Quote
Old 07-12-2018, 02:42 PM   #7
GMFL's Avatar
2014 23' International
Dadeville , Alabama
I just did you 13.5 - 15K swap on our 23D
http://www.airforums.com/forums/f142...ml#post2121062
Feel free to ask me questions.
Old 07-12-2018, 02:50 PM   #8
GMFL's Avatar
Dadeville , Alabama
I’m live in the Alabama heat also.
http://www.airforums.com/forums/f142...ml#post2124859
Old 07-12-2018, 03:00 PM   #9
ghaag's Avatar
2014 30' FB FC Bunk
Thank you for the detailed feedback, that has me leaning toward the 13,500.
Old 07-12-2018, 03:01 PM   #10
ghaag's Avatar
2014 30' FB FC Bunk
Thank you for that suggestion, I will definitely give that some thought.
Old 07-12-2018, 03:02 PM   #11
Agree on the complications of the heat pump, and the poor performance when it really gets cold. Add that to the thunderous noise you get--just like running the air conditioner side...and it makes little sense to make that much noise and suck that much power to heat an Airstream.
Our A/C system is a simple Air Conditioner, but it has an auxiliary heat strip for providing some heating in cold weather instead of running the compressor and all the accompanying noise you get with a heat pump. If you are hooked to adequate shore power, its nice to have in an emergency. For boondocking--useless!
For serious heating, we have the propane furnace that runs on 12 volt power. If we have shore power, one of the oil-filled 'radiator' style electric heaters works well for us. Especially since we have dogs (and the wall-to-wall dog hair carpet) and the surface temperature of this heater is very low. Either is a lot quieter and simpler that a heat pump.
Old 07-12-2018, 03:03 PM   #12
GMFL's Avatar
Dadeville , Alabama
My new 15K in Alabama (which is basically like living underwater) does fine dumping humidity and still runs longer than I would like between cycles.
Old 07-12-2018, 03:04 PM   #13
ghaag's Avatar
2014 30' FB FC Bunk
Thank you for the thread, I will have a look.
Old 07-12-2018, 03:07 PM   #14
ghaag's Avatar
2014 30' FB FC Bunk
Thank you for the additional feedback! Where we run into problems most often, is when we cook (which we seem to do a lot of), the current system many times cannot handle the additional heat.
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 09:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 02:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
