Old 07-16-2011, 08:04 PM   #1
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
New A/C ran for 5 min - dead?
Brand new Dometic 15K BTU air conditioner (not heat hump). It ran for about 5 min, then shutoff. Thermostat is still on, and I checked all the breakers. What could be the problem?
adwriter73 is offline   Reply With Quote
Old 07-16-2011, 08:17 PM   #2
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
is it a penguin low profile?
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 07-16-2011, 08:21 PM   #3
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Yep, and it is the breaker. It didn't looked tripped, but it was. Guess I need to upgrade.
Old 07-16-2011, 08:26 PM   #4
Becky B.'s Avatar
1964 17' Bambi II
Oh, good! My daughter has a penguin low profile & had tons of problems with it from straight out of the box. I'm glad you don't have all the issues she did! Happy camping!
Becky
1964 Bambi II
1988 Avion 32S
Old 07-16-2011, 08:38 PM   #5
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I had to replace several of the breakers in my '77 Excella rear bath model because they would trip every once in awhile for no apparent reason. It seemed to solve the problem.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-18-2011, 01:24 PM   #6
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Ok, so I figured out (after using the search) that I was using the wrong gauge extension cord. Once I plugged in, the A/C rand fine for several hours. I left, came back, and the entire system is off -- including the digital thermostat. All the breakers were fine. I am going to investigate tonight, but any thoughts on what I should check? 12V fuse for the thermostat, maybe?
Old 07-18-2011, 01:28 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
Be sure the 12v is working, and check the RJ11 connections for the thermostat. The RJ11 jack isn't really tough enough mechanically for that application but they use it anyway.
Old 07-18-2011, 02:01 PM   #8
SafariSS's Avatar
2005 30' Safari
Houston Texas , Texas
RJ 11 connectors
When my 05 was brand new the ac stopped working, as Jammer said the RJ11 connectors are suspect. They normally "click" in place however these just kinda push in. In my case it mine just was not pushed in enough. I added a layer of heat shrink to it and it is good now, has not come off in 5 years.
SafariSS is offline   Reply With Quote
Old 07-18-2011, 02:36 PM   #9
Becky B.'s Avatar
1964 17' Bambi II
If you have symptoms that are told of in this thread, you need to call Dometic:
http://www.airforums.com/forums/f427...ing-67933.html
I just updated it for the forum & others who may run across problems with their Penguin Low Profile a/c.
Becky
1964 Bambi II
1988 Avion 32S
Old 07-18-2011, 07:44 PM   #10
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Checked the RJ11 connections, and they are in place. Looked in my 12V fuse panel and no fuses are out. Would the A/C unit itself have a fuse?
A/C Pops Breaker RichWoodward Furnaces, Heaters, Fireplaces & Air Conditioning 28 07-19-2011 05:57 PM
Contractor Generator and A/C Tom Nugler Generators & Solar Power 5 07-12-2011 01:22 PM
No Power To A/C (power at breaker) vhariable Electrical - Systems, Generators, Batteries & Solar 3 06-28-2011 05:54 PM
A/C Cover...how does it come apart? KyMoonshine Furnaces, Heaters, Fireplaces & Air Conditioning 6 05-10-2011 05:59 PM
A/C Replacement malopezmo Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-12-2011 02:34 PM
