Old 06-02-2004, 06:40 AM   #1
2004 19' International CCD
Franklin , Tennessee
New A/C in CCD makes chirping sounds
Is this normal - maybe need to give it a break-in period ? We have a new 19 ft CCD that we have had about 4 months. The a/c works fine but intermittantly (more than not) makes an obnoxious chirping noise that can be heard inside and out. It is not all that loud inside, but noticeable enough to keep you awake. It got to the point last weekend, we just turned it off and sweated the night out. Searched several forums but havent found anything yet. Is this normal for an Airstream A/c unit ? This is a/c unit that comes standard.
Anyone else have this problem ?
Cory
2004 19' CCD
2004 Chevy Avalanche Z66
cmock is offline   Reply With Quote
Old 06-02-2004, 06:49 AM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
This isn't normal. We had a 11k unit in our 2003 and now a 15k unit in our 2004 neither of them did that. If you don't have a dealer close, I'd call Dometic/DuoTherm, have your serial number to the unit handy and talk it over with them. It sounds like a repair is needed. If there isn't an Airstream dealer, perhaps if there is an issue, Dometic/DuoTherm can get you in touch with a local Dometic/DuoTherm service center.
Old 06-02-2004, 01:54 PM   #3
Thanks for the response SilverTwinkie - I am taking it down to Dandy RV in Birmingham to get a leaky toilet and non working FFan fixed. Will have them check it out in addition to contacting the manufacturer.
Cory
2004 19' CCD
Old 06-02-2004, 02:03 PM   #4
hohne's Avatar
Chirping can be a bad bearing in the fan motor...
It drive me nuts, too.
hohne is offline   Reply With Quote
34' Excella 1000 needs cooler A/C cjholloway Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-17-2003 06:50 PM
understanding A/C options Lexxy Furnaces, Heaters, Fireplaces & Air Conditioning 24 08-02-2003 05:29 PM
2004 International CCD 25C Lug Nut 2002 - 2005 International 4 07-16-2003 07:24 AM
New CCD Models uwe Our Community 31 07-15-2003 12:29 PM
A/C blowing the breaker Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 13 07-08-2003 10:52 AM
