Old 10-27-2015, 12:23 PM   #1
2016 27' Flying Cloud
Reno , Nevada
New 2016 FB heater won't work
We are new to AS but not to RVing. We picked up our new 2016 Flying Cloud 27FB last week and are still settling in. We cannot get the furnace to work, although the heat pump does work. Any ideas? The thermostat is programmable, but keeps going back to the factor default even after resetting according to the directions. The heat pump is OK, although very noisy at night, but I would much prefer to use furnace as the floor ducks are more efficient and I think it would do a much better job of heating. We are on the Oregon Coast where it is very damp and cold.
Claudiaj is offline   Reply With Quote
Old 10-27-2015, 01:53 PM   #2
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Have you turned on the propane at the tanks?
Have you lit the stove to bleed the system?
Switched your thermostat to furnace?
You then wait a couple mins for furnace to kick on.
Old 10-27-2015, 02:07 PM   #3
2015 22' FB Sport
Olatje , Kansas
I had problems getting my fridge to run off propane for the first time.. Until I got the stove started and propane moving through the system...
Since it's new, if you can't get it sorted out, I'd definitely call AS support. I used them once when we first got our 22FB and they were great.
Good luck!
joekr is offline   Reply With Quote
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 14 09-26-2016 09:40 AM
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 2 10-26-2015 04:57 PM
New dometic ac compressor won't work Smokincj5 General Repair Forum 12 09-10-2014 08:45 PM
elec jack won't work, manual override won't budge? Randjg1 Jacks, Stabilizers, Lifting and Leveling 17 07-04-2009 09:19 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
