Old 08-15-2016, 08:16 PM   #1
ASTailgate's Avatar
1981 28' Airstream 280
Need To Add 2nd AC To My 34ft Excella, HELP!
Why AS didn't feel it necessary to install 2 AC units in all their 34ft Excella 1000 models is beyond me. My excella has a vent in the rear bedroom. I was wanting to install the 2nd AC in its place. I was wondering if anyone has done this and is there already bracing there? How did you do it? Did you add a second cord or how was it wired? Just really need help! Pictures and video's will be really helpful.
ASTailgate is offline   Reply With Quote
Old 08-15-2016, 08:28 PM   #2
Central , Mississippi
Here ya go
http://www.airforums.com/forums/f205...tml#post839907
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-16-2016, 12:46 AM   #3
ASTailgate's Avatar
Thank You!!!!!
Old 08-16-2016, 06:07 AM   #4
Gainesville , Florida
They didn't install two air units because people weren't whimps like we are today! I the old days 80 or 82 interior degrees using a fan was good, people went camping and didn't bring all the goodies of home with them. I've got one 13.5 unit and can keep it at 80 degrees inside using a fan to circulate the air in my thirty footer. Thats at 95 degrees outside. That's comfortable for me, might not be for you. Don't spend the money until you try it the way it is. Good camping
Old 08-16-2016, 06:10 AM   #5
If you choose to go with a second one, I would wire it independent of the trailer system so it could be plugged in or not as needed. No need for fifty amp if done this way.
Old 08-16-2016, 10:56 AM   #6
1990 32' Excella
jonesboro , Arkansas
Don't have pictures but I found a fairly easy way to brace between inner and outer skins. I used 1@1\2 in aluminum angle put together in a u channel . Over drill the inner piece of the belly of the u and mark the outside piece. Than drill a pilot hole in the outside piece for a screw of whatever size you choose I used #10 x 1\2 stainless. The gap between skins was 1 7\8 inches in my 90. 32'. You need a 14" hole for most units. I cut my sections of channel so that the u was to the inside of the opening.this gave me a channel to run wiring in. Used aluminum HVAC tape to seal corners. I put Several rivets into channel from the inside ceiling to hold in place. I do this to install a fantastic fan in mine but would work to an ad unit. You might be able to find a piece of channel the right size and cut down on some of the work. I had 2" but it stretched the corners of the opening and I did not want to start a tear in the top. Did the same in the front fan but the space was a little over 2" so came u with the angle idea for adjustability. Get a good!!!!! 20 amp extension cord to power it. Good luck.
joel is offline   Reply With Quote
Old 06-09-2017, 09:37 AM   #7
ASTailgate's Avatar
Thanks.
Do I need a 2nd AC unit? hostage46 2016 - Current Flying Cloud 46 08-13-2016 09:33 AM
Add 2nd AC to 2016 25' FC ducted version Trailer General Repair Forum 2 06-04-2016 10:26 AM
Need info on adding 2nd A/C Davis Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-23-2011 08:07 PM
Questions re: installing 2nd ac unit in rear of 34' Excella ciquing Furnaces, Heaters, Fireplaces & Air Conditioning 8 08-16-2010 12:14 PM
Leaking fuel tank in MH...need 2nd opinion. Astrodokk Mechanics Corner - Engines, Transmission & More... 5 01-07-2005 09:51 PM
