Old 05-24-2009, 08:18 PM   #1
1967 26' Overlander
Simpsonville , South Carolina
Need Some AC Advice (1967 Overlander)
I dug into my non-functioning AC today and found a mess.
Conditions found:
Compressor electric lines chewed in half
Blower motor corroded into two halves essentially.
Unit filled with leaves, twigs etc.
I cleaned up the unit best I could and removed the blower motor, capped off the blower motor leads and reconnected the compressor electrical lines. Problem is when I move the thermostat to call for cooling, all I get is a loud buzz coming from the AC control box.
Any ideas on what is going on? Best I can tell the compressor is not turning. Also, my schematic is toast...anybody out there have a copy?
Tim
TCHANNEL is offline   Reply With Quote
Old 06-03-2009, 07:45 PM   #2
Kevin245's Avatar
Hey Tim,
Nice to see some more Carolinians on board. We're located in Rock Hill, and Pickens.
My guess would be that your AC is not new and has given it's all. Between age, lack of maintenance, and use, it may be time to consider replacing I would think.
Do you know the make and model?
Welcome again,
Kevin
Eleanor Roosevelt
Old 06-03-2009, 08:08 PM   #3
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
Does it turn by hand? If so,I would change at the capaseter,they are cheep and eazy to change.
bibbs is offline   Reply With Quote
Old 06-03-2009, 08:48 PM   #4
TWaugh's Avatar
1969 25' Tradewind
1971 18' Caravel
Images: 8
I agree with Bibbs.
Change the AC starter Capacitor. Should be available through an electrical supply house.
You could also try McMaster Carr
McMaster-Carr
or Grainger
Motors > Motor Supplies > Capacitors : Grainger Industrial Supply
TWaugh is offline   Reply With Quote
Old 06-04-2009, 07:19 AM   #5
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
The new AC's are so much more efficient and quiet.
Ahab is offline   Reply With Quote
Old 06-06-2009, 06:53 PM   #6
1967 26' Overlander
Thanks for the feedback everyone. I bought my Overlander last year up in Kentucky and have been going through each system since. The maintenance history on this camper is a little sketchy but the rooftop unit is a mess. My plan is to rebuild it because I don't want to cut a hole in my shell for a new one...plus I like a good mechanical puzzle.
I have the schematic sorted out and parts for the blower in hand. The compressor capacitor is still on order. I'll let you know how everything works out.
Tim
Old 06-06-2009, 08:27 PM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Tim
New unit should mount in the same hole, using the same wiring and drain tube. IIRC the new units are the Dometic Penguin.
Aaron
WBCCI #XXXX AIR #2495
Old 06-06-2009, 08:40 PM   #8
Aaron
Aaron.
67's did not have a 14 x 14 hole.
Also the drain line was installed after production, and at the time the AC was installed.
Drain lines were not a standard "built in" until the 69 model trailers.
Also the 14" x 14" hole was not cut until the 1970 models.
The old TAC-110 models had a small hole for the fan shaft and an oval hole about 2 x 4 inches for the wiring and the 2 refrigerant lines.
Confusing I know, but that's the way Airstream did it.
1967, 1967 overlander
1967 Overlander Spare phoney Tires 14 10-07-2008 07:55 PM
1967 Overlander till 1967 Overlander 10 06-14-2008 12:33 AM
Im having trouble with my ac in 1967 overlander jonnie c Furnaces, Heaters, Fireplaces & Air Conditioning 1 05-10-2008 01:22 PM
1967 26 Overlander todcor Member Introductions 16 01-10-2008 03:20 PM
Considering a 1967 Overlander Director Buyer Guidelines 5 09-25-2007 03:39 AM
