Need high temp caulk for use around furnace external vent
Can anyone recommend a high temperature caulk that will stand up to the high temps around the furnace vent? Mine has some pretty big gaps that need to be filled.
Silicone RTV is about the only material that will go up to around 500 degrees and is formable for your application. I hate the stuff but in your situation....I think it is your only choice. Get the automotive type at NAPA that they use to form gaskets.
__________________ Lew Farber -Certified Master RV Tech (currently on Forums posting sabbatical, but lurking in the background ) WBCCI #1456 and about to resign!/VAC (assoc) #1456/ AIR # 10325 TAC# OR-1 CHARTER MEMBER: FOUR CORNERS UNIT
My Suburban furnace has an asbestos(or the modern equivelant) gasket where the pilot tube and thermocouple enter the combustion chamber through a little plate. It gets HOT. When I first got it the gasket was bad and allowed a draft to enter and blow out the pilot. Major PIA to put a new gasket in. I sealed it around the edges with ordinary GE silicone and it's still holding up after 3 heating seasons.
HTH
jerry
You might consider some sheet metal or a new cover?..... or is this on the interior of the firnace?
